RV.Net Open Roads Forum: Travel Trailers: Generator surge question
 > Generator surge question
CapeM1
Cape May,NJ
Posted: 07/10/08 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
We will be dry camping in our trailer and will be using a Honda 2000i and wanted to know is a surge protector needed when using the generator? Thanks for any help.
Mark and Vikki
2008 Gulfstream Amerilite 21MB
2008 Chevrolet Silverado 1500, Ext Cab
tvman44
Southwest Louisiana
Posted: 07/10/08 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Wouldn't hurt, anything can happen. I always say if it was made by man it can break.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
jimdubya
Paducah, KY
Posted: 07/10/08 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Using a surge protector cetainly wouldn't hurt anything, but I would not be too concerned running it without one. I would not feel the same however, with a non-inverter type generator. Since the 2000i is an inverter type, the result is a nice smooth clean sine wave.
2004 Silverado 2500 Crew Cab 4x4 6.0L 3.73
2006 Dutchman Tundra 26RL-DSL
ernestfortier
Palmdale, Calif.
Posted: 07/10/08 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
You won't get much of a surge out of a 2000w Honda generator. It is really only putting out 1800w, it goes up to 2000w only for short periods then the unit will reset itself and shut off. A 13.3 Amp surge shouldn't hurt anything.
Ernie Fortier
99 Bounder 34V
2 honda 2K paralled (for economy)
5.5 Onan onboard
96 Geo Tracker 4x4 Auto. convertable
H & E
North Texas
Posted: 07/11/08 05:41am Link  |  Quote  |  Print  |  Notify Moderator
I use a surge protector when running the generator (Honda 3000si) if the A/C is on.
jay2003
San Joaquin Valley, California
Posted: 07/11/08 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
I put my surge guard on when running the generator for only one real reason... if I run out of gas. The surge guard will cut off the circuit when voltage drops too low and won't go back on for a couple minutes once stabilized. Has only happened once because I didn't fill the genny tank. At the end it surged a couple times as it ran out of fuel.
Other than that the power from the inverter generators is very clean.
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
