RV.Net Open Roads Forum: Technology Corner: bedroom LCD TV not working ??
 > bedroom LCD TV not working ??
ford truck guy
Pennsylvania
Posted: 07/12/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
We have 19 Samsung LCD TV in the front bedroom and it will only recieve air signals? When we get to a campground , we program each tv the same and can not get any cable stations. The dealer is stumped as the coach is only 2 months old??They tell me all the connections are made and are good?
Joe and Lori
2005 Ford F250 SD 6.0
08 Montego Bay
lap527
Ocala, Florida
Posted: 07/12/08 11:26am Link  |  Quote  |  Print  |  Notify Moderator
In the settings did you switch it from cable to antenna or vice versa?
2006 Dodge 3500 dually CTD Quad Cab 4X4 / 2006 290EFS Cougar FW
10' Utility Trailer Hauling (2) 2005 Harley Road Glides
Or Gone Fishing - 2002 17' Carolina Skiff 75HP Yamaha 4 Stroke.
Hmm...decisions, decisions. So little time, so much fun!
Just Having Fun!
ford truck guy
Pennsylvania
Posted: 07/12/08 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
yes, we did that 1st. We have tried everything, I think that there may be a cut in the ire somewhere??
othertonka
Stockton, CA
Posted: 07/12/08 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have a "Selector" box near the front TV that you can select the "Signal Source" for each TV? It is usually a box that has buttons labled, Antenna, Cable, VCR, DVD, and Satalite, for the "Front" TV and also buttons for the "Rear" TV. To use cable you have to push the "Cable" button for the "Rear" TV and then go to the rear TV and go to "Setup" and select "Cable" for the source, then run "Auto channel" and it should work. If you don't have one of these selector boxes, I don't know how they send the different signals back to the rear TV and as you are finding out, you only have a Coax lead from the Antenna and not a coax lead from the "cable". Check this out and let us know what you find.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Popsie
Livingston, TX, USA
Posted: 07/12/08 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Get a piece of cable long enough, and a double female cable connector.
Then connect the input into the front TV to the cable, and the other end to the back TV.
If it gets all the cable channels now, then the problem is probably in the wiring. If it doesn't, the problem is probably in the TV.
You can also reverse the patch cable and feed the signal from the back into the front TV for a second check.
curious Bob - we fulltime with our Cairn Terrier, in 01 National Islander, and 00 Saturn LW2
ford truck guy
Pennsylvania
Posted: 07/12/08 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for those two ideas , When I get back to the trailer i will check out the box first ( I do have one ) and than if that does not work, I will run a long cable from front to back. I will advise when I get it !!!
