RV.Net Open Roads Forum: Fifth-Wheels: Maxxair and Rain Sensing Fan-Tastic Fan
 > Maxxair and Rain Sensing Fan-Tastic Fan
Bumpyroad
Virginia
Posted: 07/14/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Ed White wrote:
So, as indicated I would do, I did call Fan-Tastic Fans today to ask about the Maxxair covers. I got more or less the same story others have reported, that placing a Maxxair cover over the vent cuts the airflow by around 40%, which, the Fan-Tastic rep says, significantly reduces the ability of the fans to move air through the trailer. I was told that the rain sensor is very sensitive, so there should never be a problem unless the owner has inadvertently turned on the "rain sensor overide". I was also told that the vents can be set to remain slightly open, which allows air flow, even in the rain, and if Fan-Tastic thought covers were a good idea they would be selling them. I was encouraged to try the fans without covers before going ahead and fitting Maxxairs.
Bottom line, I have my doubts that I will be satisfied without installing Maxxairs, but I'll give it a try for a few months once the trailer arrives.
Thanks for all the input.
do a search on problems with those rain sensors. they have been posted before. I have used the standard type covers over fantastics and they have worked fine. I just use the fantastics on low speed for getting some air circulation and have no problem.
bumpy
Kodiak5er
Alex Bay NY Summer; Sanford FL Winter
Posted: 07/14/08 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
It depends on which MaxxAir model you use if it impedes air flow or not. If you use the small boxy covers, they will impede the air flow. If you use the model 800 that looks like it exhausts downward behind the vent it can't impede air flow because all that's in it are 2 or 3 blades to direct air flow and a 1/4" mesh screen to keep out the critters. The exhaust exit hole is at least 12" in diameter and all it has over it is the screen.
I use the MaxxAir model 800 for my covers and get the one without a fan motor in it. I've had two on both my last two trailers and there's been no problem with restricted flow at all.
1990 6500 Chevy Kodiak, 8.3L Cummins 450 HP
6sp Allison 3060, 3.70 R/A Home Made Air Ride
2006 Newmar Cypress - Picture's of our old one
donpop
Derby, KS USA
Posted: 07/14/08 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
The covers also help with hail protection.
2008 Ford Super Duty F350 XLT CC 4x4, LB SRW, V10, TorqShift Auto, 4.30 LS, Tow Command, Loaded
2008 Cardinal 34QS
