RV.Net Open Roads Forum: Travel Trailers: trailer towing with Hemi
 > trailer towing with Hemi
calvicso
Sheboygan ,Wisconsin USA
Posted: 07/13/08 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I have a 2005 Ram 1500 quad 4x4 w/5.7 hemi. We are looking at getting a 2008 Jayco Jayfeather 29x. Is my truck going to be able to tow this or should I consider something smaller or lighter ?
The dealership said I should be fine, but that's why I wanted to get an honest opinion from the experts on this forum instead of someone just trying to make a sale.
If I did my homework correctly, I think I should be ok.
PLEASE CONFIRM. I don't want to make a fatal mistake. Also what about WD or sway ?
Thanks
PatSak
Orlando, FL
Posted: 07/13/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
What is your rear axle gear ratio? We tow a 30 foot trailer with our 1500, however, we have the Mega Cab which sits on the 2500 frame. We also have the full tow package and the rear axle ratio is 4.10. We have a weight distribution hitch and a sway bar.
2008 Trail-lite 8308S
2006 Dodge Ram 1500, V8,
5.7L hemi engine, 4.10 rear axle ratio
2 Siberian Huskies
Fire Instructor
Upstate (Albany) NY Area
Posted: 07/13/08 09:29am Link  |  Quote  |  Print  |  Notify Moderator
I have the 2004 version of your same truck... I tow a 29.5' Rockwood that weighs in at 6,000+/- when loaded. I upgraded from WD single friction anti-sway to a Reese Dual-Cam WD system, and I also upgraded my brake controller from a Voyager to a Prodigy. The old HTT was a 23' Jayco HTT at about 5,000 lbs, and with the hitch and brake upgrades, the bigger TT tows better! I don't know if I'd want to run it up and down the Rockies, but it does fine for what I want/need.
Fire Instructor
2004 Dodge 1500 4dr 4x4
2009 Rockwood 2607
"If everyone is thinking alike, then somebody isn't thinking!" General George S. Patton
RichieO
Broward County, Florida
Posted: 07/13/08 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Our set is almost the same..2003 Quad Cab 5.7 Hemi 3.93 rear. Tows our Jayco 27 BH loaded plus alot of toys just fine. I too was concerned about the weight of the TT when we made our decision to purchase the 27BH & now wish we bought the larger 29BHS..Your truck should tow that TT or even somewhat larger TT just fine....with the 3.93 rear. I did add a set of Super Springs to our truck to help with the extra load of junk we bring along.
Good Luck and Enjoy
2005 JayFlight 27BH
2003 Dodge Ram 1500 QC 4x2 Hemi 3.92 Super Springs
Our Photo's
Bentstick
Vancouver Island
Posted: 07/13/08 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Bottom line is make sure you do your homework.
I would take some time and go to a Dodge dealership and try and find a Ram Truck Specification Guide, which should have your truck listed in it.
The last thing you need is to be broken down on a mountain pass with a overheated engine, because the people on the forum said it would be OK.
It is a good starting place to see what other people are towing with similar truck, but make sure your comparing apples to apples.
Just my 2 cents worth.
2007 Tango 257 BH
2007 Dodge Ram 1500 QC Hemi SLT 4x4
TXiceman
(Near) Houston,TX
Posted: 07/13/08 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Personally, I'd stay under 26' with a 1/2 ton truck, even a Hemi. More to towing than power.
ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
VintageRacer
Dundas, Ontario
Posted: 07/13/08 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I tow a 28' car hauler that weighs 7500 lbs, and carry an 8' truck camper that weighs 1800 lbs, Dodge Ram 2500 with Hemi, 5 speed manual and 3.73 gears. I think it does just fine, power gets me up any interstate grade on I77 at 55 mph in third gear. The 2500 chassis is a fair bit more capable and uncomfortable than the nicer riding 1500 chassis.
Brian
2003 Dodge Ram 2500 Quad Cab, Hemi, 5 speed manual, 3.73 gears, Tow Beast hitch with 24" extension.
28 ft race car hauler, Lola T440 Formula Ford, NTM MK4 Sports Racer
2004 Travel Hawk 8' Truck Camper - Roll at 16K combined weight
fla-gypsy
North Florida
Posted: 07/13/08 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
It's a 1/2 ton truck with 30' of trailer, do the right thing a look a little smaller.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
Hornet28BHDS
Parker, PA
Posted: 07/13/08 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
It sounds like you have checked out the specs and done your homework. Your Ram should have no troubles pulling the 29X. Good luck!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Prowler Doug
Northern CA
Posted: 07/13/08 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
We tow a 27 footer overall from hitch to rear bumper with the same truck. 20" wheels 392 gears. We weigh in at 6400 lbs. No problems at all.
2005 1500 Hemi Ram
2007 Fleetwood Prowler Classic 240 RKS
