RV.Net Open Roads Forum: Folding Trailers: Backing Up
 > Backing Up
10tca01
Columbia Missouri
Posted: 07/13/08 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
100ton wrote:
On edit: I just noticed that you said it is PULLING fine. Sorry about that. In case you have not guessed, I don't really know that a Palomino Pony is. If this a short trailer it will be very sensitive to any angular movement as the YnotTurbo posted.
The Palomino Pony is the smallest series Palomino makes, so yes, it is quite a small trailer.
100ton
Huntington Beach, California
Posted: 07/13/08 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
10tca01 wrote:
100ton wrote:
On edit: I just noticed that you said it is PULLING fine. Sorry about that. In case you have not guessed, I don't really know what a Palomino Pony is. If this a short trailer it will be very sensitive to any angular movement as the YnotTurbo posted.
Thanks 10tca01. I feel smarter already.
Robert
jimdubya
Paducah, KY
Posted: 07/13/08 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think you have any thing to worry about. It is just the sensitivity of your particular setup. I have a 26 ft TT and a crew cab TV that I can backup any where it will fit. But when I tried backing my SIL's PUP towed by a Ford Explorer, it was like I had never tried backing a trailer.
2004 Silverado 2500 Crew Cab 4x4 6.0L 3.73
2006 Dutchman Tundra 26RL-DSL
10tca01
Columbia Missouri
Posted: 07/13/08 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Robert
You're very welcome Robert, glad to help out!
Tyler
nny12972
NY
Posted: 07/14/08 05:55am Link  |  Quote  |  Print  |  Notify Moderator
I've heard a lot those pups out on the left coast just can't go straight......forward or backwards.....
J
bonscott
Michigan
Posted: 07/14/08 08:10am Link  |  Quote  |  Print  |  Notify Moderator
All totally normal. Just part of the deal when backing up. I remember the same thing 25-30 years ago on the farm towing trailers with a tractor. Just the nature of the beast.
Scott
TV: 2004 Kia Sorento
Popup: 2004 Flagstaff (by Forest River) 227
pete42
Jamestown, Ohio
Posted: 07/14/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
There is only one sure fire way to cure your problem.....
Sell the Jeep and trailer..........
Head for Hotel-six..... problem solved!
But really most short trailers are a lot harder to back than a long one.
When you are pulling it's like pulling a rope it follows well
Backing is like trying to push a rope doesn't work as well.
shenandoahvalley
Shenandoah Valley, Virginia
Posted: 07/14/08 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Our 30' TT is much easier to back than our PUP was. The PUP was easier than our shorter utility trailer. If it always turns left when you are backing I bet you are looking over your left shoulder. It is amazing how little movement of the steering wheel it takes to turn the trailer. AND with your short WB TV the problem is exacerbated. Takes practice.
 > Backing Up
