RV.Net Open Roads Forum: Class A Motorhomes: Storage - Tires
 > Storage - Tires
novatz
Cross Hill, SC
Posted: 07/13/08 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
When storing your rig, do you park on:
1 - heavy duty plastic
2 - plywood
3 - nothing
Was looking at the plastic route offered by "ranger design".
'08 40' Monaco Diplomat Superslide
'08 Chevy Silverado with Rampage loader
'05 Gold Wing
'41 Spouse
'05 Cat
PapPappy
Wilmington, NC
Posted: 07/13/08 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
You want "something"...plywood is cheap! You don't want to park on anything that is petroleum based...it will break down the tires.
DH Bill / DW Claudia / DD Jenn / DS Chris
The Paps! Sophie, Abby, Brandy, Kahlie and Annie
Purchased April Fools Day, 2008
The Pets
henchman
Cardinal, Ontario
Posted: 07/13/08 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
I park on what happens to be under my vehicle when I stop! Currently the ashphalt in my driveway!
Ian
1991 Winnebago Warrior 30eu
OLD RIG
2006 Chevy Uplander 3.5l
2005 Jayco Sport 165 18' 3500lbs loaded
Putnam WD w/800lb bars
Acar friction type sway control
Hoppy digital display brake control
BALANCED tires! (Please everyone, balance your tires!)
Diplomat Don
Moorpark, Ca
Posted: 07/13/08 10:06pm Link  |  Quote  |  Print  |  Notify Moderator
I bought mudflaps from a truck store. They're heavy, stay put, easy to see when backing and not a problem to drive on and off of.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2007 Dodge Dakota 4WD
AeroP
Emery, SD
Posted: 07/14/08 08:03am Link  |  Quote  |  Print  |  Notify Moderator
I park on gravel in storage about 4 months total per year. I think asphalt would leach out only when fairly new, after it is fully cured there should be no problem.
AeroP
AeroP
99DSDP
RichardFM
Fort Pierce, FL
Posted: 07/14/08 08:59am Link  |  Quote  |  Print  |  Notify Moderator
I never tried parking on "nothing" but I do park on the sandy dirt in the back yard.
2005 Itasca Meridian 34HD
Fort Mountain, GA
Nomadac
Columbus, IN
Posted: 07/14/08 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Most Tire Mfg. recommend you park on some barrier for your tires. I use pcs. of ext. grade plywood under all tires. Inexpensive and easy to use.
Arnie
2003 Travel Supreme MH
38KSO1 Cummins ISC 350HP
Car Dolly w/1996 Toyota RAV4 2WD
1963 Pontiac Grand Prix
wny_pat
Western NYS
Posted: 07/14/08 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Both plastic and asphalt are petroleum based. Guess that rules them out?
George Beggs
Homosassa, FL.
Posted: 07/14/08 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
I park on the 2x10 boards that I use for leveling.
George & Linda
1999 Pinnacle F53 6.8L V10
Banks Transcommand
sootslayer
Central Pennsylvania
Posted: 07/14/08 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
I have four pieces of rubber belting that I park on at my home. If I know I will be parked over two weeks in one place I take them along. I kinda just do it because it didn't cost may anything to do and I have read about it a couple of places. Not sure how much it helps, but I'm doing it. And if it helps extend the life of the tires on this 40'DP, then I guess it's ok..
Hank
 > Storage - Tires
