tarkin
Belle River, Ontario
Can I fill my fresh water tank at either Arrowhead or Killbear Provincial Parks?
...May the forest be with you...
PUP owner since 2006--Jayco '06 model# 1006
Days camped in '07: 21
oshawa5
oshawa 0nt
yes you can both have fresh water but just to let you know Arrowhead has boil water order
Rob and Sherry
2005 Silverado 1500
2004 Outback 21RS
To much week/ not enough weekend!
tarkin
Would I fill up at the dumping station then? I can bring up water to Arrowhead so I would just refill at Killbear.
tarkin
That advisory has been going on since last year hasn't it? Wonder what the issue is?
oshawa5
oshawa 0nt
we do not drink the water we shower and do dishes and we bring a jug of water from home for coffee and tea and case of water to drink
tarkin
Just wondering because we'll be at Arrowhead 5 days and Killbear 7 days. We'll probably need to refill at some point.
Fiddich
Outside Ottawa
Essentially, what happens is the local board of health is not comfortable saying the water is fine so they say to boil it. All the provincial parks in Ontario have the same water quality standards that are handed down by the province and are tested all the time BUT the local board of health may require something even more stringent and therefore give the water a boil order.
relaxin
Fenwick, Ontario
when you pull in stop at the dump station and top up your tank,,,, bring a couple containers or buckets and carry it from the nearest water tap and fill your tank while your set up, 5 days at one and 7 at another I would say you will probley have to fill at least once midway at each depending on your usage and size of your tank. myself I have a custom made funnel for the tank fill port and 2- 2 gallon pails, depending on wether we use the park showers or our own a tank (32 gal.) we have to refill in as little as 2 days, so 8 trips to the nearest tap and its full, nice little bit of exercise. The next TT or 5er I get I might have a second tank installed underneith with a transfer pump, and just leave empty when traveling.
Relaxin, hikin, canoin, enjoyin life
headin down the road with a 25 foot starcraft, canoe, camera & fishing rod,'86 gmc 1 ton crew cab 454 "Sheila"
a few pics from 2004
tarkin
I'll have to come up with some type of funnel if I fill up using containers, but a good idea!
As far as filling up at the dump station, should I bring my "drinking water" hose?
Don8ch
Mississauga, Ontario
Never ever fill up water at the dump station. They usually have a sign saying it is not potable water. Most of the provincial parks have a totally separate area that has a fresh water fill up station.
2005 GMC Sierra 2500HD SLT Crewcab 4x4,
Duramax/Allison, Michelin 265 LTX/MS
Pullrite Superglide, Prodigy
2006 Pilgrim 335RLSS-5
