RV.Net Open Roads Forum: Tech Issues: Old Dometic fridge problem with gas operation
 > Old Dometic fridge problem with gas operation
Christopher45103
Batavia, OH USA
Posted: 07/15/08 05:29am Link  |  Quote  |  Print  |  Notify Moderator
This is a Dometic RM-100 from 1979. It works fine on electric but just recently I noticed that it wasn't cooling properly on gas.
Overnight when it is cool outside, with the thermostat set at the normal position, the temp inside the refer will be fine. However, if you check it later in the day when outside temps are in the 80's, and the fridge door has been closed all day, the temp inside the refer will have raised about 10 degrees.
The burner flame looks fine and I was able to verify that the baffle is in the correct position in the flue. Blew some compressed air up the flue but have not removed the refer from the wall to actually clean the flue or inspect it properly.
Does this sound like a dirty flue, failing gas thermostat, or...?
Thanks,
Christopher
1979 Airstream 31' International
2004 Ford F250 SD Powerstroke
dougrainer
Carrolton
Posted: 07/15/08 06:09am Link  |  Quote  |  Print  |  Notify Moderator
1. VERIFY that the LP pressure is a minimum of 11 inchs Water Column.
2. Your model, the LP side of the Tstat is a "bypass" type Tstat. That means, since the LP flame is ON all the time, when the refer reaches temp, the Tstat has a "Bypass" that allows the flame to diminish but still stay on. Kind of like a pilot flame. That means you "May" have a defective tstat, if it is NOT staying on full flame when needed.
3. Verify your raise in temp by taking the temp of a small glass of water. Are you taking the temp of the "air" in the refer? Or using a "cheap" hanging thermometer that takes the air temp?
Doug
hypoxia
Arizona
Posted: 07/15/08 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Remove the orifice & clean it even if you can't see anything in it. Last week I had the same problem, the flame looked fine but when I took the orifice out there was a speck of something, probably a spider web. I could only see it sometimes, DW couldn't see it at all. Cleaned it, reinstalled & is working fine.
Don't poke anything in the hole.
Jim
My Trailer Rebuild Project
2008 F-350 6.4 Diesel
1990 Collins 24' 5th Wheel
2001 Jayco 311RLS 5th Wheel
ATV Trailer follows the 5er
KEBrown
Kansas
Posted: 07/15/08 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Dirty flue?
Christopher45103
Batavia, OH USA
Posted: 07/15/08 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I'm just using one of those cheesy thermometers that you hang in a fridge. The acuracy seems pretty good though.
I'll check that gas pressure though, and clean the orifice first. Much easier than pulling the fridge out to clean the flue.
