RV.Net Open Roads Forum: Tow Vehicles: Excursion photos with Re-adjusted Equalizer
Search only in Tow Vehicles
 > Excursion photos with Re-adjusted Equalizer
Chad Brooks
Tifton GA 31794
Posted: 07/15/08 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Well, after downloading an studying the Equalizer instructions, I thought I was going to have about a 15min job readjusting my equalizer since swapping from my Expedition to the Excursion. To start off with, I was suprised at how hard it was to find a level area to take measurements The best place I found was a "close" to level spot on the paved drive. After taking my intial measurements, I proceeded to readjust the Equalizer. The dealer originally installed the hitch and I had never looked at it that close. The first thing I noticed that was different than the instructions was the shims. The instructions says to use 5 and mine only had 4. After seeing that I looked over the entire install. The next thing I found was the L brackets were installed for a type A tongue and I had a type B. So, I reverse the brackets and follow the instructions as listed. The end result was a drop of 1" measured above rear wheel and the front stayed the same. A couple of things to note! I only have 4 shims instead of the listed 5, the ground I was on was not perfectly level, but close. The trailer is loaded other than clothes and the truck is completely empty. When I test drove it to a spot on the road that appeared really level, I got out and took a look and the trailer is almost dead level (according to the bubble level) with the front only slightly higher than the rear. I feel that once the truck is loaded and we get all of our clothes in, we will be very close to perfectly level. I took a couple of photos when I got home, but my yard is on a hill and the yard is very unlevel (never bury tree stumps). For those interested, the measurements when loaded to the center of the wheel opening was 38" rear and 37 1/4" front.
2002 Ford Excursion Limited V10 4X4
2008 Flagstaff 831KRSS Classic Super Lite
-Equalizer
-Prodigy
Prior RV's
2005 Montana 3380RL 5ver
1999 Holiday Rambler 33RL 5ver
1996 Jayco 302FK TT
Chad Brooks
Tifton GA 31794
Posted: 07/15/08 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer Trash 2
Santa Fe Springs, CA
Posted: 07/15/08 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
Well it looks like you have it all dialed in,
When I had to do that to my old Komfort, I found a gas station that was closed and used his slab behind his station where he used to have a alignment rack. some times a person has to be creative.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
1996 Ford F-350,Clydesdale, 7.3 Turbo W/Banks
Pulling a Super Fine Montana 2980RL
1mtnman
Colorado
Posted: 07/15/08 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Please explain a type A and type B tongue.
MTNMAN
trnfla
Tampa
Posted: 07/15/08 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
nice job
Have a great time camping,
Terry
Please say a Prayer for my 10 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
Chad Brooks
Tifton GA 31794
Posted: 07/15/08 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Type A is where your trailer coupler is more inline with the top of the frame rail. Type B is inline more with the bottom.
jmcnab
Toronto Ontario Canada
Posted: 07/15/08 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
can you post a close-up pic of your hitch setup from the side?
thanks.
02 Yukon Denali XL
08 KZ Spree 324BHS
Road Ruler
Canada
Posted: 07/15/08 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
It looks wrong!
The WD bars should be parallel with the A frame. Suspect your ball mount angle is not right or your bars have to light a rating or they are cranked up to tight.
Chad Brooks
Tifton GA 31794
Posted: 07/15/08 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
The bars are parralel to the frame. Take a closer look at the photo, it threw me off when I first looked at it too.
Trailer Trash 2
Posted: 07/16/08 12:57am Link  |  Quote  |  Print  |  Notify Moderator
Road Ruler wrote:
It looks wrong!
The WD bars should be with the A frame. Suspect your ball mount angle is not right or your bars have to light a rating or they are cranked up to tight.
The top picture looks like they are not parralel to the A frame but look at the second picture, It looks very even to me.
The only thing I see is when the TV is loaded with the kids and stuff, will the angle change very much?
