RV.Net Open Roads Forum: Smartest WD Hitch & anti-sway set-up 4 our Hybrid advice
Search only in Towing
Open Roads Forum  >  Towing
 > Smartest WD Hitch & anti-sway set-up 4 our Hybrid advice
jamielew
NY
Posted: 07/17/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Hi; we own a Jayco 17A Hybrid camper and have been towing with Dodge Dakota Club Cab just fine on short trips. We want to take on 6 hour drive and are looking for advice on which WD Hitch and Sway bar set-uo we should buy. Any advice is will be greatly appreciated. Thanks
mkirsch
Rochester, NY
Posted: 07/17/08 06:52am Link  |  Quote  |  Print  |  Notify Moderator
Make sure your trailer is compatible with a weight-distributing hitch first. This information will be in the instruction manual. Many of the smaller trailers don't have a heavy enough tongue to withstand a weight distributing hitch, and the tongue will bend instead of distributing the weight.
One of the hitches with integrated sway control would be best, IMHO. Reese Dual Cam, also sold under other brand names. You probably need the lightest spring bars available.
Dick_B
Palos Heights, IL USA
How much does the RV weigh. Maybe you don't need either.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
bikendan
Napa, Cal.
Posted: 07/19/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
the highest rated here are the Equalizer or the Reese Dual-Cam. the best place to buy the Equalizer is RVWholesalers.
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
6MISFITZ
Fort Erie, ON, CANADA
Posted: 07/19/08 11:27am Link  |  Quote  |  Print  |  Notify Moderator
As Dan said above - Rvwholesalers.com
Equal-i-zer Brand Name
or
Reese/Drawtite/Hidden Hitch Dual Cam
Mike.
Mom, Dad, 4 kids, 2 Camping Dogs
Express 2500 LS (135"WB) 6.0L, 4.10, G80, PYO wheels, HENSLEY & McKesh
Prowler Regal 320DBHS w/QUAD BUNKS
MISFITZ RACING
MFCC Member
Rallies Attended 4, 7 Un-Rallies
BarneyS
S.E. Lower Michigan
Posted: 07/19/08 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Unless you have at least a 400lb tongue weight, forget about the Dual Cam. It needs a minimum of that much to be effective. I second the recommendation to make sure your trailer is capable of using a WD hitch. If it is not, then the friction sway control would probably be your best bet.
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
jamielew
NY
Posted: 07/21/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the advice. Here's what I know; unit dry is around 2700 lbs, GAWR 2900 lbs, GVWR 3450 lbs, do not know where to locate tongue weight?. The manual (which is a general manual for smallest 17A (which we have)and a 30'travel trailer and only thing distinctly listed is ball height and size (our is 2" ball 16.5" height having said that; they do recommend a Class IV WD hitch for all towable travel trailers and in BOLD print recommend anti-sway ro sway control. States contact your hitch/RV specialist,etc. So I'm thinking Reese Dual Cam or similar? Any further advice is greatly appreciated.
Jamie
BarneyS
S.E. Lower Michigan
Posted: 07/22/08 08:14am Link  |  Quote  |  Print  |  Notify Moderator
I think in your case I would go with the Equal-i-zer hitch
in the 600/6000lb configuration. It is the smallest one they make. It will provide the WD you want plus give you sway control in one unit.
It is their stock #14-2926 600lb/6000lb $449.99, with free shipping, and unless you live in Ohio, probably no tax either.
Another choice would be the Pro Series hitch by Reese in the 750/7500lb configuration. It is a bit cheaper in price and should work well also.
Code: #49578, Price: $330.95, also with free shipping and no tax.
In both cases, you would need to add the proper size ball to your order.
Barney
* This post was edited 07/22/08 08:23am by BarneyS *
Yodelpup
Cornelius, OR
Posted: 07/22/08 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Your trailer is the same dimensions as my popup (17', 2900# dry, 3500# GVWR). I added sway to the trailer and Airlifts to the truck and it pulls like a dream, even over bad roads. A 7500# WDH seems like overkill unless you intend to upgrade to a bigger TT at some point.
08 Fleetwood Saratoga
07 Toyota Tundra 5.7
harland98
NH
Posted: 07/24/08 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
Do you need one? Those weights seem pretty small to me.
Tony
