beliveauj
Austin,Tx.For The Winter
For those of you that have portable generators where do you put them when you travel?
Jim & Jeanne Both now retired, fulltiming and loving it.
Buddy and Emma (Silky Terriers)
2003 Ford F350 Crew Cab "King Ranch" Power Stroke 6.0
2007 Mobile Suites 36SB3 N0MSU
Chief45
Porterville, Calif.
Chained it to the bed of the truck between the hitch and the cab.
(wife's from austin mn)
Arcamper
Fayetteville, AR
Chief45 wrote: Chained it to the bed of the truck between the hitch and the cab.
Same thing I do.
2007 Keystone Laredo 29RL 5th
2003 Ford F-250 SD Crew Cab 4x4 6.0 Diesel
Pullrite 16k Superglide with Super Rail kit
Brakesmart
JRC
Rancho Cucamonga CA
Yep, same location. Instead of a chain I have looped a cable through the rails of my 5th Wheel mounting brackets that are attached to the bed of the truck. I can also secure bikes with this application when the generator is not in that location. If you have a hitch installed to the rear of your coach you can attach a box back there. I believe you can find the ad in the back of Trailer Life.
1999 Dodge 2500 QC CTD manual 5 speed
2001 Carriage Cameo LXI F27RKS
WOJO 1
Sparks, Nevada
In the front storage compartment on a slide out tray. Works very well for me.
2002 Duramax 4X4 CC SB
2005 Cougar 296EFS
Reese 16K Slider
2 Hondas in the front storage compartment
TTT Mirrors
smkettner
Truck bed with a flimsy cable lock.
CPAfiver
Broussard, LA
Bolted and locked to a Hitch Haul on the rear of fiver.
2006 Ford F-250 Crew Cab 6.0 Power Stroke Lariat FX4
2004 Crossroads Paradise Pointe PF32RL
Reese 16K Kwik-Slide, Garmin Streetpilot 2720(aka "Sunshine")
Yamaha YG4000D
family5th
Central Coast, California
Locked in the truck bed here also.
Ford F350 PSD CrewCab DRW
Heartland Sundance 2998RB
tvman44
Southwest Louisiana
Chained in the truck bed.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
TubaPete
Comstock Park, MI
Arcamper wrote: Chief45 wrote: Chained it to the bed of the truck between the hitch and the cab.
Same thing I do.
Me too.
Tuba Pete
