RV.Net Open Roads Forum: Forum Technical Support: Spell check not working
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Spell check not working
Jerrybo66
AZ
Posted: 07/17/08 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
The spell check on the forum works ok but the one in my Outlook Express quit working. The icon is still there but "faded out". Does anyone have an idea of where it went or how to get it back? ....Thanks..
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
fishboat1
southern ca
Posted: 07/17/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Spell check on RV Net still not working.
Mike H
2007 Allegro Bay 34XB FRED
2002 Dodge Dakota 4 wheel drive Toad 4.7 v8
Four Winns fishing boat
pulsar
Lewisville, NC
Posted: 07/17/08 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
It was earlier, but is not now.
It's hard to come up with a reason as to why it started working and then quit again.
The same is true about the online/offline indicator and the edit indicator.
At least the preview box is working properly, for the time being.
Tom
j2catfish
Newport, NC, U.S.of.A.
Posted: 07/17/08 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Turn off your Pop Up Blocker, then click the Spell Check block. Then turn the Pop Up Blocker back on. Spell Check will work and Pop Up Blocker is off just a second. Works for me.
F350 Diesel; Teton 5er;
Native Texan - Transplanted Tar Heel
Retired USMC
Semper Fi !
MichDoc
Michigan
Posted: 07/18/08 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Mine isn't working either, and I tried turning off the pop up blocker. No help.
pulsar
Lewisville, NC
Posted: 07/18/08 07:15am Link  |  Quote  |  Print  |  Notify Moderator
There were a number of issues created with a software update. Those issues are limited to the RV.Net portal. If the issues on the RV.Net portal make it uncomfortable to use, then we suggest that you use one of the other portals.
Alternate "portals" to the RV.net Open Roads Forums
Spell check works and the preview boxes work on the other portals.
BTW, the preview box can be totally removed by changing a preference setting on you preferences page.
Tom
