traxtermax
UPSTATE NEW YORK
Gale Hawkins beat me to it but as long as there's going to be a vote, here's one for 90.
Bobbo
Memphis, TN
I vote 95. Note that the long mark is halfway between two of the small marks.
Bobbo, Linda and the furry kid (German Shepherd)
'07 Winnebago Outlook 31C on a Ford E450 Super Duty Chassis
NRA Life Member
Near N35 12 17 W89 50 57
Southwind85
Where I Park
littleb wrote: The Gauge is reading 95 psi. The dash in the middle of the 0 is the 0 amount. like 10,20 30. the little dash marks are 2 lbs incriments.
Correct.
You'll notice that dash in the middle of the 0 is slightly darker than the rest of the lines. That's the 0 number.
The line between the numbers is the #5 increment.
The Good Life
traxtermax
UPSTATE NEW YORK
I can see both lines of reasoning but the increments don't seem to work for either 90 or 95.
DeweyClawson:
Please use another gauge to determine the pressure of one car tire, then use the above gauge on the same tire. Tell us what the reading is and then maybe we can figure out the rest -- and don't tell us it's 92.5 either!
Edit: fixed spelling and added last phrase.
edited 07/18/08 10:42am by traxtermax *
Wherever I happen to park
95.. But check it with a known gage, NOTE that these gages may say on the name plate that cries "Accurate" however they don't do well when it comes to accuracy
But compare it against another known gage
smkettner
If you need 95 I would put another 5 in it. Better to have 5 too much than too little. Also on those the indicator can fling out a bit, make sure you try to push it in so that it is against the internal movement.
I would like to see the full scale and the intended pressure range of the gauge before I give an official guess.
Dutch&Dutchess
North Carolina
95 psi. The small darker line is at the 10,20.30 etc. the small lines in between are @ 2 lb increments. the long line under the number is between the 4 lb and 6 lb marks, hence 5 lbs. 95 psi!
Dutch & Dutchess
2006 Dodge MegaCab 3500 Laramie
2004 26E31DS Titanium w/ Bugroom
Kodiak5er
Alex Bay NY Summer; Sanford FL Winter
Dutch&Dutchess wrote: 95 psi. The small darker line is at the 10,20.30 etc. the small lines in between are @ 2 lb increments. the long line under the number is between the 4 lb and 6 lb marks, hence 5 lbs. 95 psi!
Exactly, what he said, it's 95 psi. I've been using these gauges for almost 60 years. Boy, I guess we can argue over almost anything!
Some of you guys are a lot like my grandchildren, you probably can't read a clock unless it's a digital one.
edited 07/18/08 12:20pm by Kodiak5er *
1990 6500 Chevy Kodiak, 8.3L Cummins 450 HP
6sp Allison 3060, 3.70 R/A Home Made Air Ride
2006 Newmar Cypress, Pics of '93 Mountain Aire
traxtermax
UPSTATE NEW YORK
If it's 95, EXACTLY where is 90?
Kodiak5er
Quote: If it's 95, EXACTLY where is 90?
90 is always half way between 80 and 100.
My wife even got 95 from the picture.
