RV.Net Open Roads Forum: Class A Motorhomes: Pac-Brake Sticking?
 > Pac-Brake Sticking?
Craig P.
Posted: 07/18/08 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I recently returned from a trip in the mountains. Before leaving, I serviced the pivot points on my Pac-Brake, as best as I could. I could not get the Pac-Brake to open & close by hand, so I lubed the areas that I could get to with an approved synthetic lubricant.
The first few times I used my brakes while descending the mountain, the coach made a loud whistling noise. I couldn't tell for sure, but it sounded like the Pac-Brake was possibly hanging up. The noise went away after 3-4 applications of the brakes. This has never happened before.
Anyone experience anything similar?
Craig
2005 Providence 39J
2007 Tacoma PreRunner Double Cab Dingy
2002 EZ-Go Custom Electric Golf Cart
Thousand Trails & Coast to Coast Members
rbdtanasi
Foley, AL
Posted: 07/18/08 08:41am Link  |  Quote  |  Print  |  Notify Moderator
You must use a 12-volt dc jumper to activate the pac brake. Best to disconnect the electric plug, then connect a good ground to one pin and 12-volts to the other. That is the only way to operate the pac brake. Use only Superlube that Pac Brake makes. It can be ordered through Camping World.
Rex - 01 Monaco Diplomat being pushed by an 08 Honda CR-V
Dynasty40
Hangtown, Northern California
Posted: 07/18/08 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Do you remember the tune it was whistling....might help...
Dennis and Debi
Monaco Dynasty Baron 40PFD
Craig P.
Posted: 07/19/08 09:03am Link  |  Quote  |  Print  |  Notify Moderator
That is a great idea, thanks. I will give it a try.
I called Pac Brake tech support a couple of weeks ago, and they said that in addition to Pac Brake brand lube, SuperLube (which can be found at most Ace Hardware stores) is an authorized synthetic lubricant.
Craig
