RV.Net Open Roads Forum: Things to look for when purchasing a used Roadtrek
 > Things to look for when purchasing a used Roadtrek
briansac
California
Posted: 07/19/08 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased a used 2006 Roadtrek RS Adventurous, 37,000 miles on Ebay. I am going to have it checked by an RV service center before I pay for it. Besides checking the engine compression, fluids, and making sure the appliances are working what else should I keep an eye out for?
Thanks
steveh27
Grosse Pointe Woods, MI
Posted: 07/19/08 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased my Xplorer 8 years ago used. I knew most of what needed repaired, but not all. I found out later the A/C needed replaced. The plumbing underneath had problems & the dump valves needed replaced. The shocks needed replaced. The other things I knew in advance.
Rodger
Tucson, AZ.
Posted: 07/19/08 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Your under warranty, so I wouldn't worry too much. Just make sure everything works. Might have the brakes checked. The generator, if it has one, should have around 50 hrs or more on it if it has been exercised properly. If it only has a few hours on it, I would make them run it under load (AC) for about 15 to 20 minutes to make sure there are no problems.
Good luck, and have fun.
Visit My Roadtrek
Hey, check out the new RV.Net Blogs!
clayway
Posted: 07/19/08 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
I would check roof seams for rust, my roof had to have everything removed and repainted. Same year as this one.
* This post was edited 07/19/08 06:24pm by clayway *
