Dick A
Spokane Valley
Last week while driving home on the freeway in Western Montana at about 60 mph I had the tread on my right inner dual tire separate but the tire not blow out. The tires on the coach are Toyo 235/75 – R16 M54’s and are four years old with just over thirty-five thousand miles on them. I have rotated the tire every year, had the front end aligned, and always keep the tire inflated at 80 PSI. The coach has also been weighed and is close to GVWR but not overweight.
Has anyone else had this problem with a Toyo tire? The tread loss did take out my extra sewer hose carrier tube but caused no other damage.
*Please see updated informational post on page three of this topic.*
last
edited 07/22/08 10:20pm by Dick A *
View edit history
Check out the RV.Net Blogs at: blog.rv.net
RayChez
Barstow, Ca. USA
NOPE! Best tires I have ever had. Had Michelins before. Mine are 265/75 22.5
wcjeep
Tacoma, Wa
Did you buy the tires 4yrs ago or are they 4yrs old? Also, how much weight are you running on them?
http://abcnews.go.com/Video/playerIndex?id=4826897
dentmac
Southern Ontario, Canada
The last 2 paragraphs refer to TOYO
http://www.jlbreport.com/2007/06/14/tire-failures-on-recreational-vehicles-cause-injuries-and-deaths/
cdzranch
Snowflake Az
Possibility that it somehow became damaged or lost pressure and separated. Check the DOT #'s and see if the other came from the same lot. Might check the NHTSA to see if there was a recall for those tires.You can sign up for recall updates to be sent to your email.I have Toyos on both motorhomes 16's and 19.5's no problems so far. I will be interested to see what others say.
Dan and Cindy FMCA# 402249
2002 Itaska Suncruiser 37ft (1) slide W22 Workhorse chassis; 1990 Komfort Trendsetter 25ft 454 4bbl carb
Tow VW manx bug; '07 Honda Shadow 750
Snowflake Az.
"If you don't learn something new every day, you've wasted that day!"
Gale Hawkins
Murray, KY
Dick if you have ever changed the direction of rotation of the tire that could be the cause I was told by one tire store (major truck tire dealer in town) when I told him I was going to rotate our 19.5 wheels ourselves. Rear outsides can only go back and forth with opposite front positions.
Some radials do not like changing directions even though they are not sold as unidirectional tires. He said some never cause an issue and others separate very quickly after the direction has been changed.
Dick A
Spokane Valley
wcjeep wrote: Did you buy the tires 4yrs ago or are they 4yrs old? Also, how much weight are you running on them?
I had all six tires installed new four years ago. I am about 300 lbs under maximum load on each rear tire. All tires were checked for 80 lbs inflation just a few days prior to the failure. Also, there was very little change in the outside temperatures for several days and the average temperature was around 80 degrees so not really very hot.
Dick A
Spokane Valley
Gale Hawkins wrote: Dick if you have ever changed the direction of rotation of the tire that could be the cause I was told by one tire store (major truck tire dealer in town) when I told him I was going to rotate our 19.5 wheels ourselves. Rear outsides can only go back and forth with opposite front positions.
Gale, I find that information very interesting. I am going to print a copy of your post and show it to the Lew Schwab folks when I go in tomorrow.
cdzranch
Snowflake Az
It's an old school way never to change the direction of rotation an radials. I scraped knuckles and busted wrenches in the automotive and medium truck field for almost 40 yrs. and to this day no one will convince me to change the direction of rotation on any radial tire.
driveby
Vancouver BC Canada
Dick - 4 YO purchase doesn't necessarily mean 4yo tires. I'd be curious to see the real age. Sounds like you take care of them. btw, ever hit a pothole that might have beat on that tire more than others?
2008 Itasca Sunova 35J Class A
1997 TJ Sahara, hard and soft tops and AC
Held together via Roadmaster Falcon 2 tow bar and stopped by US Gear Unified Brake system.
