RV.Net Open Roads Forum: Towing: Excessive left rear tire wear on tow vehicle
Search only in Towing
Open Roads Forum  >  Towing
 > Excessive left rear tire wear on tow vehicle
ronbarb
Sonora, CA
Posted: 07/19/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
My left rear tire on my tow vehicle wears down evenly at 4 times the rate the right rear tire does when towing our TT. I have checked the tire pressure and it is where it should be. We are preparing for another West to East coast trip and I had to have the un-used spare put on the left rear. The tire people said it was normal to do that because of that being the power side of my 4X2 pickup. He said it was common when towing a TT. He said it even did it when towing his 5th wheel. I towed a small 5th wheel across the U.S. twice for a total of 18,000 miles and didn't experience unusual tire wear.
Does this sound normal to you RVers? Do any of you out there have this kind of a problem of more wear on one side than another? Is there anything that can be done to lessen the wear?
My setup is a 2005 5.3 Silverado 1500 4X2 and a 24'TT with about 5700 lbs GVWR. The hitch is an "Equal-i-zer" with built in dual anti-sway bars. When setting up the hitch I was able to get the pickup and TT perfectly level with there being only 1" difference in height between the front and back of the TT. On the freeway we average 60mph and rarely go 65.
Thanks in advance for your ideas and help. Barbron
Ron Pugh
Turbo Diesel Dude
Green Mountain, NC
Posted: 07/20/08 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Because of it's the "powerside" of your trucks rear end. Need to rotate the rear tires more often so you get more even wear. JMHO
charles weidman
chuckcjax
Jacksonville, FL
Posted: 07/20/08 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Unless you like to do burnouts and have an open differential that makes no sense at all. If the tire wears evenly but much faster than the one on the right my only explanation is a tire compound difference. If it wears unevenly then there may be an alignment issue at play or a suspension problem.
Very curious indeed...
2006 Flagstaff 829BHSS
2007 Silverado LTZ 5.3L Gasser
Our Camping photos
JohnnyT
Goshen New York
Posted: 07/20/08 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from dinghy towing forum
NHguy
NH
Posted: 07/20/08 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
I think there are a lot more right rear tires worn out on RWD vehicles. I'd have someone check the diff.
05 F150 FX4 Supercrew, 5.4, 3.73 LS, Jordan Ultima 2020 Brake Controller,
04 TrailCruiser 30QBSS, Battery Disconnect,
Dual Cam HP, Ultra Fab Power Tongue Jack, Bal Lockarm Stabilizers
smkettner
Posted: 07/20/08 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Both tires get equal torque if the differential is operating correctly.
Could be a bad tire. Try a full 4 wheel alignment check is my only thought.
SoCalDesertRider
SanDiego, CA, USA
Posted: 07/20/08 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
You have any 16-yr old boys driving your truck? Burnouts will do that...
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
JFordBronco
Ball, LA
Posted: 07/20/08 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
I rotate all 4 of mine with every oil change. This is interesting though - the "powerside" of the truck.....I wouldn't go there again if that is what they really believe
2007 Nissan Titan Off-Road w/ leveling kit---THIS THING IS A PIECE OF JUNK
2008 Jayco Jayflight 28BHS
Me, wife, one little girl and one little boy
all along for the ride.
john b
anywhere USA!
Posted: 07/20/08 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Something has to be amiss in your rear suspension when loaded. Is it possible you have a loose or bent axle tube on that side? A good alignment shop should be able to sniff it out for you! Good luck!
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2004 Crossroads Paradise Point PF33Rl 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
Caddywhompus
Southeast WI
Posted: 07/20/08 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Clearly the idiots who told you that have no idea how a differential works. Equal torque is applied to both rear tires are all times, by design. As a result both tires would wear perfectly even.
Unless someone was doing a lot of burnouts, in which case the RIGHT tire would wear out faster (assuming an open differential). The right tire always breaks loose first because the rotational twist of the driveline puts more pressure on the left tire (newton's law).
Your situation is curious indeed. I wonder if there was a teenager involved who wore out the tire, then rotated it to prevent daddy from figuring it out. Whatever caused it there is surely a variable that hasn't been discovered yet.
'04 Ford Freestar (Primary tow vehicle)
'05 Subaru Forester (Backup tow vehicle)
'65 Bethany popup (best popups ever made!)
Looking for a tow vehicle
Minivan towing
