RV.Net Open Roads Forum: Class A Motorhomes: Water Regulators
 > Water Regulators
want-a-be
Indiana
Posted: 07/21/08 08:13am Link  |  Quote  |  Print  |  Notify Moderator
I am in the process of buying a Watts Regulator for the RV. What I am wanting to know is what Model is best for this application and where is the best place (price wise) to purchase it?
Thank You
Want-a-be
downtheroad
Tumbling Waters, Washington
Posted: 07/21/08 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Give this guy a call. He is a long time RVer and really knows his stuff and has a full line of regulators.
Water Regulators
GMC Duramax/Allison (LBZ)
08 Komfort 277TS Our Rig Pic
Reese Dual Cam HP
JFG
TN
Posted: 07/21/08 08:33am Link  |  Quote  |  Print  |  Notify Moderator
The H560 has a dial readout and is sized for use on std garden hose size fittings. The problem is that I have never ben able to ind this model at Lowes, Home Depot or Ace. You may have to locate at an RV dealer/parts and accessory place. You can probably do a search and order it on-line as well.
Fred
Maanpa
Central Point, Oregon
Posted: 07/21/08 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Adjustable Water Regulator at Campworld. $50.00
Koran & Darlene
Creole & Cajun (Our 4 Legged Kids)
2007 Itasca Suncruise 38T
PressurePro/Progressive SP
Steer Safe/Vantage BB/Stowmaster
Hughes Autoformer
2004 Rubicon
Goodsam/PA/F394282
ronfisherman
SE Michigan
Posted: 07/21/08 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I have this one from CW. Gives good volume and pressure.
Saf-TTE tire monitor
Wherever I happen to park
Posted: 07/21/08 11:14am Link  |  Quote  |  Print  |  Notify Moderator
I have seen watts regulators at selected camping world stores
Lowes and Home Depot have them
I would look for model with 3/4" threaded inlet and outlet
WHY you ask
Because one of the easiest hose adapter fittings to find, most every hardware INCLUDING Lowes and Home Depot has 'em. is a male or female hose end with a 1/2 inch IPT inside thread and a 3/4 IPT outside thread on the other end
So to connect this one to a hose you need 2 pieces of brass.. .Nothing more
Any other model you need more
urmine351
fort smith, arkansas
Posted: 07/21/08 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
I have a water regulator that I leave on my hose, and I have seen as high as 110 lbs. at a few campgrounds. What is the plumbing rated in most motor homes? My regulator is set for 45, and I don't think I would want to go over 60.
1996 Safari Serengity, 3126 Cat,Allison 6 speed, 38' DPNS, 2005 Honda Element,vip tow brake. doran tire sensors, Magellan750Nav,
and 1 good looking wife, and missy and Alex(died 11-03-06) and AJ, born 09-06-06 my carins.
FMCA # F374886
urmine351
Posted: 07/21/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
old guy
Oregon (pronounced Or e gun)
Posted: 07/21/08 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
it's been a long time since I set my regulator, I'm not sure what pressure I set it for. If you go to HD or Lowes you should be able to get the gage, and all the fittings all in one stop. The one at CW does have every thing installed all ready and it is cheaper than if you buy the parts and put it together.
John&Joey
Northern MN
(Baby it's cold outside)
Posted: 07/21/08 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I bought THIS ONE off of E-Bay. I'll plumb it into the remote water filter with quick disconnects on the hose ends.
 > Water Regulators
