RV.Net Open Roads Forum: Class A Motorhomes: Using old gas?
 > Using old gas?
RealtyRoy
NW Oregon
Posted: 07/22/08 10:56am Link  |  Quote  |  Print  |  Notify Moderator
I was talking with a friend last night and we are wondering about using old gas from his boat.
Because of health problems he has not been able to take the boat out for about 6 or 7 years. I know gas turn into a varnish like liquid over time but he has about 120 gallons in the boat and with todays prices it would be nice to be able to use it.
Is there something that can be added to bring it back? Octane booster maybe?
Thanks for any info you may have on this, he really could use this fuel if it is usable.
Thanks,
Roy
May the roads and skies always be clear, and the firewood nice and dry!!
tom_kat
way upstate new york/lake george area
Posted: 07/22/08 11:06am Link  |  Quote  |  Print  |  Notify Moderator
adding fresh gas would help but 6 to 7 year old gas will be pretty flat and lacking power if it would run at all and not gummed up.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
RealtyRoy
NW Oregon
Posted: 07/22/08 11:09am Link  |  Quote  |  Print  |  Notify Moderator
I was afraid of that but thought their might be an additive he could try.
Thanks
Daveinet
il
Posted: 07/22/08 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Poor some in a VERY SMALL tin can and throw a match in it. I've seen some gas that would not even burn that was only a year old. On the other hand, I have a friend who died because he couldn't smell the old liquid in a 50 gallon drum and thought it was water. He cut the top off with a torch and now is in Heaven.
Dave
FMCA F298817
'83 Revcon Prince 31' FWD
502 w/Thorley's & Magnaflows,
Howell/Edelbrock MPFI, Koni FSD,
Class A built for gear heads
My Revcon Website
Revconeers Forum
XP activation frustration
loedman1
Napa, Ca.
Posted: 07/22/08 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Thanks,
Roy
Stick your nose in the filler and take a sniff. If it smells like gas then give it a try if it smells like something evil then pump it out and start over.
Sully2
Cincinnati
Posted: 07/22/08 11:23am Link  |  Quote  |  Print  |  Notify Moderator
I wouldnt run it in mine. Id get a burn permit ( typically FREE) and set fire to it all
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Jim@HiTek
Gresham, OR, USA
Posted: 07/22/08 11:29am Link  |  Quote  |  Print  |  Notify Moderator
When I was a kid and lawn mowing season started we'd just pour a small amount on the sidewalk and light it. If it burned we used it. If it didn't we'd dump it and put in fresh. If it burned weakly, we'd mix in new about 50/50.
I think your friend should pump it out in any case, then add anti-varnish products to stabilize what's left in the tank. And do what other magic is needed to prevent rust.
Meanwhile, run the burn test on what's been removed and then make your decision.
Whatever you do, do it safely.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site.
1994 Fleetwood Bounder
Cummins Diesel, 190HP, 36.5'
Black Rock Lava Park, Nevada
troll3193
SouthWest, MI USA
Posted: 07/22/08 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
a 120 gallon gas fire... great idea...
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
Dynasty40
Hangtown, Northern California
Posted: 07/22/08 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Don't listen to the naysayers....torch those 120 gallons...sounds like a "hot" idea....
oh but do it safely.....lol....Don't use it..7 yr old gas is worthless
Dennis and Debi
Monaco Dynasty Baron 40PFD
RealtyRoy
NW Oregon
Posted: 07/22/08 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies, I think I will take a smell and if it smells like gas than I might see if it burns. I have quite the burn pile going and I could use it to get the pile going. If it doesn't light than I guess that's it.
Seems a shame to let all that gas go to waste, at todays prices that's a little under $500 worth of fuel.
Oh well.
If it does burn I could offer it to all the neighbors both his and mine for their lawnmowers
Thanks again
Roy
 > Using old gas?
