RV.Net Open Roads Forum: Towing: Reducing tongue weight
Search only in Towing
Open Roads Forum  >  Towing
 > Reducing tongue weight
skip298
South Bruce Peninsula Ontario Canada
Posted: 07/23/08 05:04am Link  |  Quote  |  Print  |  Notify Moderator
tvman44 wrote:
Can you move anything from the front to the rear behind the axles?
Can someone that knows answer the above question please..
I Have s similar problem with PIN weight....(a little to high for me..all other weights are Ok.) IF I carry water in the fresh water tanks(which is behind the axles), I know I will add to my Gross weight but will it lighten the PIN weight by weighing down the back...????? thanks..
summutt2002
(somewhere in the mountains of Utah)
Posted: 07/23/08 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Sorry I misled Larry...I was simply referring to the weight....the sag was in the Suburban. The Ex experience remains to be seen......still working on suspension,tires, other stuff. Don't expect a whole lot to change, though. Still the same weight to deal with.
Great wife, 3.1 dogs and no money..LIFE IS GOOD
'01 Excursion Ltd 7.3L PSD pulling a '06 Prowler 260RLS, Equal-i-zer, Prodigy
mkirsch
Rochester, NY
Posted: 07/23/08 10:57am Link  |  Quote  |  Print  |  Notify Moderator
It works like a see-saw or teeter-totter. Any weight behind the axles will counterbalance an equal amount of weight at an equal distance in front of the axles.
Put 500lbs 5' behind the axles, and 500lbs 5' in front of the axles. Your pin weight will not change, but the gross weight of the trailer will.
