RV.Net Open Roads Forum: Travel Trailers: Keystone unconcerned
 > Keystone unconcerned
eriede
Florence, Ms
Posted: 07/22/08 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Mr. Riede,
I want to apologize for the issues you are having. Keystone RV has reviewed your information that was sent in and we respectfully decline participation with this issue. If you have further questions please let me know.
Thank you,
Carmen Tom
Customer Relations Specialist
Keystone RV Customer Service
Phone: 866-425-4369
Fax: 866-273-1451
________________________________________
Sent: Tuesday, July 22, 2008 11:49 AM
To: Gary Patterson
Cc: Carmen Tom; Trisha Mascarenas
Subject: Update on fender well problem
Any word from Keystone on the 2nd request?
Here are a few post from Trailer Life and Keystonecamping website of people having the same problem.
I am spreading the word to as many people as I can using the internet to alert people to Keystones lack of quality control and poor customer service when they have a know design problem. Over 200 people have viewed my post on Trailer life and Keystonecamping.com website as of 7-22-08.
Posted: 07/21/08 11:52pm Link | Quote | Print | Notify Moderator
Hi,
I have 2008 Keystone Passport 285RL. Towed it several thousand miles no problems....but... I noticed delamination just below door where outside stove top is located. Felt under the plastic wheel well cover and the fiberglass covered luan plywood extends under the bottom of the floor into the wheelwell. Reach under your wheelwell plastic cover and you will feel the wall extending into the wheel well about an inch or two. Mine was wet and found the rain water from the wheels throwing water upward soaks the plywood and wicks up the wall causing delamination. I bought a caulking gun and a tube of Silicone RTV and some dishwashing gloves and "painted" the bare wood with the silicone and covered the bare end edges so water will not get into the wood. Also sealed with a bead between the plywood and the metal housing in the wheel well. Put the plastic trim back on and it should be ok.
I called Passport dealer and they said they would take care of it but I wanted to save further damage until I got back home. This may save having it returned to the factory and new walls installed.
Good Luck
zippys
Larry & June
40 ft Monaco Diplomat DS towing 01 Ford F150 Supercrew
Post subject: index.php?name=PNphpBB2&file=viewtopic&p=36221" \l "36221index.php?name=PNphpBB2&file=viewtopic&p=36221" \l "36221Posted: Jul 17, 2008 - 11:48 AM
Premier Member
Status: Offline
Well today I checked our Everest to see if it indeed was any better then the Passport; Ha! It has the same exposed luan plywood running the length of the large slide as well as the no slide wheel wells. Totally exposed and waitin for water....I cannot believe Keystone does such butcher work. I really can't.
The new and most recent problem with these things is the bedroom slide floor rotting out from water coming in through the poorly sealed roof. And now this?
What garbage; what absolute garbage!
Premier Member
Status: Offline
Thank you for bringing that to my attention!! I just checked mine and although no damage has been done yet, I plan on treating the exposed cut edge with something, even paint or varnish would be better than nothing at all. Mine was cut very sloppy around the fender skirt and I need to trim it out before I protect the raw edge, I can't believe that I missed this all this time, thank-you again.
_________________
2008 Passport 280BH
2008 Toyota Tundra V-8 5.7 Liter
Curt WDH 1000/10000 W/Friction Sway Control
Prodigy Brake Controller
Erich, Amanda, West and Colt
2003 Ford Expedition
2006 Keystone Zeppelin Z291
Equalizer Sway Control
Voyager brake controler
Rvndave
Medina, Ohio
Posted: 07/22/08 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
We have delamination on a Keystone Outback my friend just bought. It is only 7 weeks old. I will have to check for this problem before more damage happens. You have me worried about what Keystone is going to do for him.
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
Lovedays
Greensboro, NC
Posted: 07/22/08 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
Ahh man! My wife just showed me a Keystone Outback Travel Trailer she likes after searching forever. Now I have to tell her we can't buy it because their service stinks.
Thanks for the post though.
Eric, Melissa, Morgan, Andrew
and Sam the Camping Canine
2006 Starcraft Antigua 235SRG
2004 Toyota Tundra SR5 Double Cab V8
www.thelovedays.com
mwebber78
New England
Posted: 07/22/08 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
After 2 recalls (tires, propane system) our friends are still happy overall with their Keystone.
I don't think they are all junk, but recent posts about the Passport which is the Zep replacement leads me to believe that the same poor construction standards are being applied to the Passport line.
Hopefully you all find some resolution.
Michael
2 DD's and my DW
6 Acre's of Maine
2009 Crossroads Cruiser CF31SB
2008 Chevy 2500HD Ext. Cab LT 4X4
Camping Pictures
eriede
Florence, Ms
Posted: 07/22/08 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Keystone will most likely, treat you right as you are still in warranty. But beware when warranty is up. It is up... Even if it is a know problem.
fla-gypsy
North Florida
Posted: 07/22/08 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
I am quite happy with my Keystone Hornet. I don't think I will join your Keystone bash. I will say I hear more complaints about the Passport than any other Keystone product.
05 Super Duty XLT CC 5.4/3.73 5 sp auto Torqshift
06 Keystone Hornet 29 RLS/(The"Cracker Cabana")
Reese HP Dual Cam
Camping Photos
Northeast Florida Camping Club
St Andrews SP cult member
Lovedays
Greensboro, NC
Posted: 07/22/08 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
What do you hear about the Outback?
Humpty
Clayton, NC
Posted: 07/22/08 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
www.outbackers.com
2007 Challenger 33DBB w/ Sidewinder
2002 Chevy 3500 CC DRW D/A
B&W Companion Hitch / Prodigy
taxfreebonds
Candler, NC
Posted: 07/22/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
We're looking for new but stepped into a pre-owned 2007 Passport the other day and were surprised by the very soft floor. Sorry about your troubles.
The Walders
2009 Outback 310BHS
2007 F-350LB 4x4 Diesel
eriede
Florence, Ms
Posted: 07/22/08 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
[quote=fla-gypsy]I don't think I will join your Keystone bash.
Hey, Dont get me wrong. I love my Zeppelin. And I think the Passport is a pretty desent trailer from what I have seen.
After having said that when you expose a major design problem and give them proof. pictures, other owner claims and they just say sorry. There is something wrong.
We just returned from 7 days in our Zepp. 700 mile round trip without a single problem.
Thats great. Keystone should be big enough to correct there mistakes.
