RV.Net Open Roads Forum: Travel Trailers: 09 Wildwood 30BHBS Hard to open door
 > 09 Wildwood 30BHBS Hard to open door
VonH
Grove,OK
Posted: 07/23/08 10:58am Link  |  Quote  |  Print  |  Notify Moderator
We are in the middle of a long trip with our new 09 Wildwood 30 BHBS. Ive ran into a weird problem with the front door. If the trailer is slightly out of level the door is VERY hard to open. For instance if you raise one of the stabilizer jacks too high the door will become hard to open. I cant believe that is either right or acceptable. Ive had 5 other trailers and none of them have done this before. Has anybody else run into this problem and how did you address the issue with the mfg?
Thanks
colochoclab
Arvada, Colorado
Posted: 07/23/08 11:23am Link  |  Quote  |  Print  |  Notify Moderator
My entry door on our Jayco will stick from time to time. I haven't had the chance to adjust the door (if possible). Mine sticks just at the latch, not anywhere on the frame.
Good luck!
-Lab
2008 Nissan Titan LE Crew 4x4, DOHC 5.6 V8, Big Tow Pkg.
2006 Jayco JayFlight 29FBS
Equal-i-zer Hitch
Prodigy Brake Control
Member of clubtitan.org
"Hershey" the Chocolate Lab (Co-Pilot)
"I asked God for a true friend: He sent me a Labrador Retriever."
VonH
Grove,OK
Posted: 07/23/08 11:38am Link  |  Quote  |  Print  |  Notify Moderator
I cant see how this can be an adjustment issue as it will be fine one time, barely stick the next time, then you have to almost pry the door open the next time.
rmw1990
East Central Georgia
Posted: 07/23/08 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Our new Jayco has been this way since we have owned it. When all the jacks are down and it is close to level it is fine but the door will stick at the latch if the trailer is torqued. Such as one tire being higher than the other three or one jack being way tighter than the others. It has not been a major source of contention for us since it is easily remedied by having the trailer level or close to level. Someone else has probably experienced this also and will be along shortly to tell you how they fixed theirs.
Have fun on your trip!!
2000 F250 4X4 CC 7.3PSD
07 Jayco Jayflight 28 RBS
trailer folks
iowa
Posted: 07/23/08 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
sounds like frame flex,,,,, check your frame for cracks, check to see if its bent,measure all four corners when your on a flat surface
Hornet28BHDS
Parker, PA
Posted: 07/23/08 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
Call the dealer and ask what they think. Good luck!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
dfm11
Ohio
Posted: 07/23/08 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 09 Wildwood 25RKS and had the same problem with the back door.
I made a note along with several things and will see my dealer in about a mth.
Me my Wife & Jack & Roxy
2009 Wilwood LE TT 25RKS and 2001 Suburban
Moto: NEVER EVER GIVE UP!!!!
Photos
JTCR
Central Mass
Posted: 07/23/08 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
mine is hard to open when not level sometimes
2004 GMC 1500 4x4 Extended cab short bed 5.3 3.73
2007.5 Jayco 328RLS
