RV.Net Open Roads Forum: Travel Trailers: Downsized
 > Downsized
Caprail
Georgetown, TX, USA
Posted: 07/23/08 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
After much consideration and a lot of shopping, we just downsized from our class A to a new Jayco Jay Flight G2 23B. Since the Quad cab Hemi was already in the driveway it seemed to make sense to use it to pull a TT. Anyway, we're excited about the new rig and anxious to get out on the road. One question: will a Yamaha 2400 generator start and run a 13.5 Coleman Mach AC? I'd go ahead and buy the 3000 if I could figure out an easy way to get it in and out of the back of the truck. Any ideas?
Chris & Beth
2007 Dodge Ram 1500 Quad Cab Hemi
2008 Jayco Jay Flight G2 23B
sweethome alabama
Scottsboro, Alabama
Posted: 07/23/08 07:59pm Link  |  Quote  |  Print  |  Notify Moderator
The 2400 won't run it on high, probably be ok on low. Most people use 2 Honda 2000's and use the parallel kit to tie them together. I have been wanting one myself. Just haven't invested yet. The 2400 comes out at about 20 amps but is probably not rated at that continuous load. Really hard to say if you don't take a amprobe and put on it to see what it actually pulls when the compressor kicks on the a/c. With the 2 Honda's it would be ok whatever you wanted to do. Anyhow welcome to the Travel trailer way of life Camping is camping regardless. Have fun Mike
Might want to look on your a/c and see what the amp rating is for it. Will give you a ideal what full load amps is for it.
04 suburban 1500
00 silverado 1500
05 jayco 27bh
Couldn't get rig to post,so here is my burgler alarm!!
JSFord
Frederick, MD via Baton Rouge, LA
Posted: 07/23/08 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
The 2400 most likely will run it. See posts by 2manytoys. It runs mine on my Jayco 31bhds 2007, mach 3, no ps, just the regular one. Of course I did have to order the hard start kit from my local dealer for $50. Before that it would only start it if it had been running a while off of shore power. I love my 2400.
Me, the wife, two girls-5 yrs. & 1.5 yr.
2007 Jayco Jay-Flight 31BHDS
2007 Chevy Silverado Classic 2500HD D/A Crew Cab LT3 SWB 4x4
Hornet28BHDS
Parker, PA
Posted: 07/24/08 05:09am Link  |  Quote  |  Print  |  Notify Moderator
Good for you! Enjoy the new TT!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
tvman44
Southwest Louisiana
Posted: 07/24/08 06:33am Link  |  Quote  |  Print  |  Notify Moderator
Might have trouble starting.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
SoCalDesertRiders
SanDiego CA
Posted: 07/24/08 07:36am Link  |  Quote  |  Print  |  Notify Moderator
We had a long discussion about generator loading and unloading up on the 5th wheels forum last week. I think the topic was called 'loading a generator' or something like that.
I posted pics of the ramps I made to load/unload my generator with. That was on my other screen name- SoCalDesertRider (I had to make a new screen name to enter the forums through Woodall's cause RV.net forums quit working). Anyways, check for that discussion up on 5th Wheels and you will get a few different ideas on the topic.
HighCover
Fort Worth
Posted: 07/24/08 07:40am Link  |  Quote  |  Print  |  Notify Moderator
The Yamaha EF2400 will run a 13.5k AC unit all day long. I do it in 100degree Texas heat. And yes, I run that sucker on HIGH! Only caveat, when I run the microwave, I click the AC off.
2007 Tahoe, 5.3L
Rockwood 2306
Star Gazer
Nicholasville, Kentucky
Posted: 07/24/08 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I run a 13.5k with my Honda 2000 and it works well, but only with it running and nothing else. However it did give me problems once at about 6000' elevation.
2000 F250 PSD 4x4
2005 Four Winds 18B (mobile observatory)
My Astronomy Pics
1990 Sea Ray 350 Sundancer
Caprail
Georgetown, TX, USA
Posted: 07/24/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks so much for all of your insights, after looking at the "generator loading" discussion, I ordered the Yamaha 3000 from Wise sales. I'm going with the ramp idea and found a good way to set it up inexpensively... http://www.mainstsupply.com/product.cfm/8/56/30139
Thanks SoCalDesertRiders for your good ideas and pictures.
mehwwh
Posted: 07/24/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Congtrats on the new TT. We have the same model & thoroughly enjoy it.
'03 Silverado 1500, Ext.Cab, Z71 Off Road, 4X4, 5.3L, 3.73 rear, AutoMeter Trans Temp Gauge, Putnam Class IV
'08 Jayco JayFlight G2 23FB, Reese WD Hitch, HP Dual Cam Sway, 800# Trunnion Bars, Barker 3000# Power Tongue Jack
 > Downsized
