RV.Net Open Roads Forum: 93 RT rear door leak
 > 93 RT rear door leak
popr
NH
Posted: 07/24/08 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 1993 RT 190 that has a problem with rear window leak. I took off the screen and find considerable drips on each side. Any ideas how to seal the leaks? Could it also be coming from the drip edge along the top of the window??
Any advise would be greatly appreciated!
Paula
Pieface190
Hastings,MN
Posted: 08/03/08 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem on my '96 Dodge RT 190. It turned out the top center brake light lense (mounted on the roof)was loose and leaking. The gasket was shot and the fiberglass had broken around one mounting screw. Water off the roof ran behind and inside and then through the ceiling and onto the rear window. Repair as necessary.
