RV.Net Open Roads Forum: Travel Trailers: ladder mount bike rack?
 > ladder mount bike rack?
bob444psk
seattle
Posted: 07/24/08 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
any body mount their bikes on the back ladder ? i see theyhave them for sale for around 85 dollars, any likes or dislikes? the ladder on my komfort seems pretty strong, my 2 bikes might weigh around 45 pounds total. thanks.
2002 f350 crew cab short box, leer canopy, tinted windows, 3 inch level kit, 315 toyo mt tires, 8 inch nitto rims, superchips 1805 flashpaq tuner, afe stage11 intake system, 4 inch turbo back exhaust, auto meter guages, pulls our 2004 komfort 27ts tt.
maddog348
Bakersfield,CA
Posted: 07/24/08 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
Did for quite a while on class'C'. Just snugged 'em up close & tight(rack slipped over top step 2 arms out)high enough to be out of the way of the tail lites. Ran that way for years no problems. Then bot new bikes and center frame cofiguration not the same - wont hang. Now use rack on top of toad if need to take.
lat471
Lebanon, PA
Posted: 07/25/08 05:35am Link  |  Quote  |  Print  |  Notify Moderator
To bad your not closer you could have mine & 2 bikes. Used it couple of times but the new coach's ladder doesn't seem as rigid as the last one so we went to folding bikes. Personally I believe there are better bike rack solutions.
07 Cameo LXI F35FD3
R Taj-We-Haul
chasfm11
Dallas/Ft Worth Areas
Posted: 07/25/08 07:37am Link  |  Quote  |  Print  |  Notify Moderator
We have a ladder bike rack. If I had a choice, I wouldn't use it but since I really don't have an alternative, it works OK. Here are my suggestions:
1. Most ladders are mounted with just screws. Carefully go over every ladder mount point and make sure that the screws are tight. The problem is that the weight of the bikes can cause movement and that could crack your RV
2. When you put the bikes on the rack, be sure they cannot swing. On mine, the front wheels could so I built "spacers" out of 2" square PVC by cutting slots in both ends and putting pipe insulation around where those slots made contact with the front forks on the bikes. I also built a spacer between one of the ladder rungs and the fork on the first bike.
3. Pull the bikes tight against the spacers using the straps with the rack. On mine, the ladder rack instructions recommended pulling down with the straps. I compromised and pulled down and in by going a rung or so lower than the bikes with the strap. I make sure that the spacers are firmly locked in place when I'm through tightening the straps.
I can only say "so far, so good." I haven't had problems with the bikes moving in transit. I had DW follow me in the car and watch when I went over bumps. For me, any movement is a problem.
2000 Georgie Boy Landau 36'DP Cummins 5.9, Allison 1000 5sp
1994 Saturn SL1 Toad, Falcon2 Towbar, BrakeMaster Toad Brake
