jarredondo03
Los Angeles
Just upgraded my TV from half ton to 3/4 ton. I would like to tow with in the next two weeks. Would it be wise?, considering I will not have the recomended 500 mile break-in.
Thanks,
Jason
RustySocket
SW Washington
Read the manual... its your truck however.
edited 07/24/08 11:09pm by an administrator/moderator *
wcjeep
Tacoma, Wa
The 500mile break in period is for the gears. IMO it's important. You have two weeks. Take it out for a Sunday drive.
dedmiston
So Cal, USA
You'd better start driving.
I was a hundred and fifty miles short on the day I was scheduled to pick my trailer up. I did laps around the 210/10/60 until I hit 500.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600
Toys:
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
- 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
kknowlton
Wisconsin Border Country, IL
If you have a couple weeks, take some day trips, and drive the long way to work. It won't take long - just feels that way.
SoCalDesertRider
SanDiego, CA, USA
You're actually better off doing your break-in in traffic or on local roads than on the freeway, due to the constant rpm of freeway driving. During break-in you should be varying the rpm and not doing hard accleration or towing.
92F350 CrewCab 4x4 351/C6
LoadNGo service body
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
B&W TurnoverBall g-neck Curt Magnum rr DrawTite ft
HD springs Rancho9000s Bilsteins poly sway bushings
4.56's & Lock-Rite rear
beemerphile1
NE Ohio
I don't worry about break in. Run it the way you plan on using it from day one. The break in warnings are only for the protection of the manufacturer.
There is a myth that metal components have to wear into each other. It is BS. Metal can NEVER touch metal! If your bearings or whatever ever touch metal to metal they are instantly destroyed. All components are protected with a film of lubricant between surfaces. They NEVER actually touch.
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
rdam
Lake City, Florida
If your read'n or post'n, you ain't driv'n..... Better get goin'
2006 Weekend Warrior LE 3505
2004 Ford F-250 Supercab 6.0L Diesel/Auto
08f450psd
Westminster, Maryland
I got my new TV to 500 miles before towing. Just doesn't seem to be that big of an inconvenience to follow manufacturer's recommendation.
If you were on the east coast, I'd offer to put 500 miles on it for you, as long as you buy the fuel. I'm just that kind of a giving person...
wayne_tw
South Dakota/Georgia
Jason, you obviously will do whatever you think is appropriate, but the advice you should follow is the experts, not someone who just has an opinion, and a wrong one at that. Who are the experts? The people who designed and built yur truck, and their advice can be found in the owner's manual. You should follow it exactly.
