RV.Net Open Roads Forum: General RVing Issues: water pressure
 > water pressure
54ktmracer1
michigan
Posted: 07/25/08 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
we have a 09 raptor 3612ds and i`m not happy with the water pressure.the dealer said it was normal. we had a 07 wildwood sport 32srv that i thought had better water pressure.
any advise on safely increasing water pressure? thanks
targaboat
sulphur springs, tx, usa
Posted: 07/25/08 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Pump working or on city water?
Fly Boy
sclark
Minnesota
Posted: 07/25/08 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Is it equipped with a water filter? You may want to change the filter out to a less restrictive one to increase your pressure. Good luck.
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
JFG
TN
Posted: 07/25/08 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
If on pump, it will depend on the pump size. Pumps range from 1 gal/min to 3.5 gal/min. You need to see what size you have and check its thru put rate using a gal container and watch.
On city water, you have a fixed regulator that controls the water pressure. Some are set at 40 psi... others at 60 psi. Take your reg off and replace it with a Watts 560 or equivalent.
If you have a water filter, some are rated at 1 gal/min. You may want to replace with a higher capacity filter.
Also, check your outside shower. It needs to be turned off at the knobs not just the push button on the wand.
Fred
 > water pressure
