jcramin
Memphis, TN
I have a Weekend Warrior FS2500 Toy Hauler. It is a 30AMP system it has a IOTA DLS-30 converter and two deep cycle batteries.
When I have it stored at home I keep it plugged in.
When I have it plugged in at home to a regular 120V wall outlet with nothing on in the trailer. The only things taking power are the radio, but not turned on it is just taking power, and the CO detector.
NOW for the questions....
Why does the fan in my converter run so much ???
Should it run that much ?
Would a larger converter do anything better ?
Is it ok to keep the trailer plugged in all the time with the converter fan always running ?
Thanks,
J
2007 Weekend Warrior FS2500
2005 Dodge Ram 2500 QC 4X4 HEMI
dodge guy
Chicago, western subs.
My fan (for the charger) only runs more when the batteries get weak or get older. is it possible the dealer gave you 2 bad batteries?
Wife kim
Son brandon 7yrs
Daughter marissa 6yrs
Dog shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear
Reese HP dualcam,Prodigy brake controller,
Air lift air bags.
Better to have a bad day of
camping than a good day at work!
jcramin
Memphis, TN
dodge guy wrote: My fan (for the charger) only runs more when the batteries get weak or get older. is it possible the dealer gave you 2 bad batteries?
Well the trailer is 2 years old.
J
ronfisherman
SE Michigan
Our MH that is about the size of your TH has a 60 amp converter. Fan runs only when something large is used (like water pump). 30 converter will work but 60 amp would be better.
Does the area where converter is mounted have ventilation? The cabinet where our is mounted has ventilation. Air flow in and out.
Saf-TTE tire monitor
bldrbuck
Boulder, Colorado
With nothing on the batteries may have a bad cell causing the converter to try to charge a bad battery. Take the batteries to a battery dealer or auto supply store and have them tested. Since they will have a surface charge it would be best to let them sit disconnected for several hours. Unplug the shore cord.
93 Ford F350 Turbo Diesel, DRW, Crew Cab. PullRite Hitch. 90 Nomad 28' 5er, 375 Watts Solar, 2800 Watt Yamaha Generator, 1750 Watt Inverter, 4 Trogan T105 Batteries, Spare tire and wheel and folding ladder. Me, wife and 2 spoiled Maltise furkids.
JFG
TN
Is you refer on? Even in ac mode, it uses dc to power the control board.
If refer is off, maybe you want to consider unplugging from ac.... what's it doing for you?
The fan cools the transformers and circuit boards in converter. Most Circuit boards are rated to about 105-115 degrees. with the outside temps being as high as they've been, they are needed to keep things below those specs.
Fred
jcramin
Memphis, TN
ronfisherman wrote: Our MH that is about the size of your TH has a 60 amp converter. Fan runs only when something large is used (like water pump). 30 converter will work but 60 amp would be better.
Nope very little ventilation where it is mounted.
jcramin
Memphis, TN
JFG wrote: Is you refer on? Even in ac mode, it uses dc to power the control board.
Nope the REF is off.
ctbailey
New England
Is the 30 Amp converter ALSO a 3-stage charger?
If not, this baby will be constantly pounding the battery bank with 13.6 +/- volts. That constant output would tend to heat the converters circuit boards up. When a battery reaches 90% "full" a good charger will step down the voltage flowing to the battery, which should result in a cooler converter/charger.
The iota website is unclear about whether it provides "staged" charging.
edited 07/25/08 05:15pm by ctbailey *
Craig T. Bailey, PE
- '03 Chevy Silverado 4.8L 4x4 Short Bed
- '04 Surveyor SV235RS by Forest River
beemerphile1
NE Ohio
jcramin wrote: NOW for the questions....
Probably because it is in a cabinet where there is a lot of trapped heat. Especially if the cabinet is on the side hit by the sun.
Yes, it is thermostatically controlled.
A larger converter would put out more amps and probably charge your battery faster. Go to the Iota website and do some research, you might want to buy the smart charger plug in attachment.
Maybe, is it really always running? How about at night when it is cooler? It should stop when temperatures cool down.
Thanks,
J
Tim
"Okay, I admit it, the only thing I'm really good at is being me."
Support the "No Child Left Inside Act"
2006 Weekend Warrior FK1900
1998 Ford E150 4.6L
1996 BMW R1100GS
2005 Trek Madone 9spd.
1995 Burley tandem
