RV.Net Open Roads Forum: Toy Haulers: Fuel Station Leaking
Search only in Toy Haulers
 > Fuel Station Leaking
Elmoclayman31
So. Cal.
Posted: 07/25/08 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all, I went to get the TH ready to go and noticed a small wet spot under the door to the hose and nozzle of the fuel station. I have turned on the pump and pressurized the system but not actually used the nozzle to fill a can or bike or something. The leak looks to be coming from the threaded connection between the hose and the nozzle itself. Is it possible that the preassurizing of the system is causing the leak? Is there a "teaphlon" tape like product that I could put on the threads of the hose connection to stop the leak? Any help would be appreciated.
2007 Chevrolet 2500HD 6.0L
2008 26ft Thor Vortex
01 Suzuki RM250 (mine)
83 Yamaha PW50 (the boy's)
05 Roketa 70cc Quad (the princess')
Living my American Dream!
Badhabt
Puyallup, WA
Posted: 07/27/08 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same thing going on with my nozzle/hose connection (since I bought it 2 years ago). If I have the pump on and do not activate the nozzle I get some slight seepage at the connection of the hose and nozzle. I noticed the white thread goop applied from the factory on mine and thought about redoing to see if it would solve the problem. I just make sure I turn off the pump and drain the hose when I'm refueling before stowing.
06 F350 4X4 Crew Cab Dually Tow Boss
07 Raptor 3612DS
92 Banshee - sons now
06 YZF450 50th Anniv Edition - sons too
06 Raptor 700R 50th Anniv Edition - mine
06 Wolverine 450 - wifes
07 Wolverine 450 SE - my other toy
04 YZ250F - spoiled sons newest toy
Elmoclayman31
So. Cal.
Posted: 07/28/08 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks....we have an appointment to see if we can get it fixed before our long trip in 2 weeks. Gotta love a warranty.
CrazyTed
Hoollieville #214
Posted: 07/28/08 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
I went to the local Northern Tool and purchased a better fuel nozzle as I though mine was cheap. No problems.
CrazyTed
www.CrazyTed.us
Va Bch, VA
2006 KTM 450 XC
1997 Triumph Tiger 900
2005 Chevy 2500HD 4X4
2008 CrossRoads CrossTerrain TF36DS
trail-explorer
WA
Posted: 07/31/08 09:35am Link  |  Quote  |  Print  |  Notify Moderator
for repairs done at home, I'd recommend thread putty like plumbers use on propane or natural gas lines rather than teflon tape. it's often referred to as "pipe dope"... usually the section of lowe's or home depot that has steel pipe is where you find it, where they have the thread cutting machines for custome vut pipes and stuff
jcramin
Memphis, TN
Posted: 07/31/08 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Just for your info, My Weekend Warrior FS2500 had the same leak, BUT the factory fixed mine. I dont know what they did to fix it.
2007 Weekend Warrior FS2500
2005 Dodge Ram 2500 QC 4X4 HEMI
mapguy
Puget Sound
Posted: 07/31/08 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Unless something is cracked -fitting or nozzle housing it is a simple job to unthread the nozzle, coat the threads with sealant rated for gasoline service, then reassemble. Teflon tape -even the stuff rated for gasoline sevice does not work well for this application IMO. I like the proper RectorSeal paste product for this usage.
Map Guy
* This post was edited 07/31/08 12:48pm by mapguy *
