ret-miner
ontario
Just wondering what kind of sealant to use. plan to take out and reseal top marker lights on my class c any ideas would be appreciated
fordsooperdootydieselsmoker
OrangeCountyCalifornia
The OEM sealant on the last few Jayco's we've had appeared to be silicone.
JUrban
Delaware
Our Bus uses silicone, but we have fiberglass under it. If you have a "rubber " roof, I'd use Dicor.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
Cool Mike
Mendocino. Calif.
If you could find LED bulbs as direct replacements, you could use a good second generation silicone sealant and never have to worry about it again.
On things I dont plan on having to take apart again, I use 3-M Marine sealant. Its rated for below the water line, comes in bright white, it does take about 7 days to completely go off, but it wont leak, and it looks great. It should, at $22. a tube.
2001 27' Four Winds Class-C E-450 V-10.
Buick Park Ave Ultra, Ford Ranger PU, JD 500 backhoe.
1941 Farm All "A"
Shifer
Rochester, NY
I use a bead of 100% silicone clear caulk to seal my marker lights. nevr had a leak yet! 1987 Mallard 28' on a Ford E-350 chassis.
jcamp123
Putnum County, New York
I replaced all the running lights and tail lights on my C with LED lights. I used clear silicone and works great, no leaks and and they sure do look good at night.
2000Coachman with super slide
1974 Super Beetle With 2110 cc. engine
A teamster for 38 years
Widowed,Retired and traveling
Joe and Tara my Toy Poodle
TreeSeeker
San Diego
The biggest problem with silicon is that if you ever need to recaulk, nothing sticks to silicon, even silicon. In my experience silicon degrads and comes loose. In those areas where it does not come loose it is very difficult to remove, and if you can't get it all off, then nothing will stick to it.
I use ProFlex RV (www.campingworld.com).
Note that most clearance lights are made to leak--they have vents to allow the water to drain out. Unfortunately this also allows water to get in. I also seal all the holes in the inside of the face plate where the wires and fittings go through.
