I recently installed my barker vip 3000 powered jack but there is hardly any room to put my propane tank cover on. I can't figure out how to move my propane tanks back a little. Has anyone had this problem. And yes I did try to move the barker around to see if it would give more clearance. Thanks for the help.
If you have the room, just remove the LP tanks, unbolt mounting plate and move it. Bolt mounting plate back, on replace tanks and you should be good to go.
2000 4X4 Excursion Limited 6.8V10, 4.30, 122,000 miles
Hellwig Rear Sway Bar
Roadmaster Active Suspension
2004 4X4 Expedition 5.4V8, 3.73 210,000 miles
2000 Coachmen 297 RKS
Reese Dual Cam Sway Control
Prodigy Brake Control
Our propane tank mounting has always been welded to the trailer frame, so moving it is easy or not, depending on your access to welding. Sometimes you can trim the plastic cover so it fits better or easier.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
I have the same problem with our TT. The tank shelf is welded in place and can't be moved. I found that the auto switchover/regulator is the main interference for the cover so I loosen the wing nut that secures the tanks in place and push the regulator as far to the rear as I can then tighten the wing nut. It makes it a little easier but not much. Our cover has holes on top that allow access to the tank valves so the cover only needs to be removed once or twice per year when the tanks need to be refilled.
I also have limited clearance between the power jack and the tank cover. I just have to push or pull a little harder to get the the cover on or off. At least I don't have to worry about the cover blowing off going down the road or in a storm!
2008 Sabre by Palimino, Model 28RBFWS
2006 GMC 1500HD 6.0 4 SPD 4:10-1
Bob-USAF (Ret) Barbara-Soon to be retired
No pets, just two beautiful granddaughters
