crazymcs
New York
hello. We are looking to purchase a 5th wheel in about a year. i have some questions on the hitches. Can you remove the hitch out of the bed of your vehicle when you are not towing, or is it bolted down. never had a 5th before just TT. i dont want to lose my bed space all the time. We are going to get a short bed so we would get a slider. Is there certain brands to stay away from. Any help would be appreciated. Thank you in advance.
2006 Tahoe
2006 Antigua 195CK
Dad and Mom, and baby
Cooler full of Beer
danfoote
sussex, new brunswick
Hi
I would look on Ebay for a hitch - you could save quite a bit of money. The hitch is removable when not is use.
Also remove your tailgate when installing and towing the trailer.
crazymcs
New York
how hard is it to remove and put back in. is there always a bracket installed even when you take out the hitch.
abc40kids
Virginia
Very easy to remove,better w/two people.I have never removed my tail-gate to tow my 5er or remove hitch.
Jeff,Julie,Amber,Brandon,and Casey
Forest River Cardinal 362bhs Trail-air pinbox
'05 Chevy duramax dually 4x4 crew cab
JGRVING
BUFORD, GA
We remove ours all the time. A little heavy but not too bad.
DUANE, JENNIFER, PUGZ & SMOKEY(In Spirit)
BUFORD, GA
'07 CROSSROADS CRUISER 29RK
SO MANY PLACES, SO LITTLE TIME
Rvndave
Medina, Ohio
Many leave the hitch connected to the trailer and use the 5er jack to lift it off.
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
C.B.
APPLETON WI USA
A Pullrite Super Glide with SuperRail mount kit gives you a clear bed(no brackets).
Link to www.pullrite.comand watch the video.
I've never towed with my tailgate off. When unhitched my tailgate and Jack Rabbit tonneau cover are closed and locked.
edited 07/26/08 07:38am by C.B. *
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
TORQSHIFT AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE
PRODIGY BRAKE CONTROLLER~C-BETR MIRRORS~ROTOCHOKS
CB Family Fleet
Butch&Barb 03Cardinal~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 04Jayco
tjar66
Portland OR
I have a Pull Rite Superglide with the under bed kit. when I pull the hitch out there are ony four holes in the bottom of my bed. I take it out regularly. It comes apart in three pieces with the base being the heaviest. While I have removed and put it in it by myself the help of my 14 yo son is a tremendous help.
2006 Dodge Ram 3500 Cummins
2007 Desert Fox 305j
2004 TRX 450r Mine
2005 Yamaha Raptor 350 Wife's
2006 Honda 300ex Sons
2007 Honda 250ex Daughter
Jrebhun
Western Pa
I have a block and tackle attached to the ceiling of my garage and use it to hoist out the 5er hitch- weighs abt 200 lbs and I can do this myself with the tackle. Whats left in the truck bed are two rails which are bolted to the truck frame thru the truck bed. If you have a bed liner, they will cut out the liner where the rails are going in order to have a solid contact with the metal bed. If you have a spray-on liner, they just bolt thru it instead.
Pearlbum
North Louisiana
I have a Reese hitch and when removed there are two rails left in the bed running across the bed. The bed isn't perfectly flat, but for me it is fine and I can carry whatever I need. B&W makes a hitch that when removed leaves the bed flat with no rails. There are a number of good hitches out there. Decide what your needs are and have fun looking.
2008 Keystone Outback Sydney Edition 28FRLS
2006 GMC 2500HD Duramax/Allison
Reese Pro Series 15K Slider
