tropical36
Southwest Florida_USA
We'll, we're back in Florida on the way home and are now experiencing those famous afternoon tropical rains, so now we have a leak for the first time since we've owned this rig although there is prior evidence that it has done so before.
So, what's the best cure for a leaking TV antenna? It's right above my computer chair and so far I've turned the crank a turn and hung a towel up there, which seemed to stop it or at least help
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal, with a tag axle and one slide, on a 1997 P32 Chevy chassis....7.4 Vortec Engine
dawgs3
n.c
seal it with eternabond,you can find it on eternabond.com and it has an instructional video for application.
BlackSilver
East of Heaven, North of Hell
Assuming this is the ubiqitous Wingard "batwing" antenna, there is an o-ring seal arrangement that works only if the antenna is fully extended or fully retracted.
Hans, KØHB & Colleen, KØCKB
Master Chief Radioman, US Navy
'04 Prairie Schooner 34FBR Platinum XL Camping Trailer
'08 3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
My rig (Click)
WA1RI
FL
The other culprit is the boot over the coax cable. Is your desk under the crank?
Bill & Jolene / FL
1997 Southwind 35P
2006 Yamaha 1100 Classic &
1970 Norton Commando 750 in state of recuperation (Almost road ready!!!)
6x12 Enclosd trailer
JerryofWV
Charleston, WV
I had the same problem a few weeks ago. I could not see any cracks in the caulk. I caulked a couple of places that looked like they could leak. Next rain, same problem.
I took the antenna out, cleaned off all the old caulk and caulked between the antenna base and the top of the motor home. Reinstalled the antenna and then caulked around the edges.
Has not leaked since. Not that big of a job and works better than putting caulk on top of caulk.
Jerry & Dee Dee Pauley
1998 Pace Arrow 36S, 1 Slide, Tag Axle, Triton V10, Front Konis, Rear Track Bar, Banks Ram Air, 2000 Tracker Toad
The happiest people don't necessarily have the best of everything. They just make the best of everything they have.
Don Don
Pleasant Grove, AL {Suburb of Birmingham}
Seal it. Go on the roof, you can more than likely see the crack in the old sealant.
Don Don
Double post
tropical36
Thanks for the replies...will take a look, first chance I get. Still seems as though it helped to turn the crank up a half turn when it was all the way down. The leaking started all at once and went down my back sitting here in front of the computer. This KOA has cable, so the antenna wasn't up and it really poured in until I did the above.
