RV.Net Open Roads Forum: Class A Motorhomes: Its hot
blknomad
ferrum va
Posted: 07/26/08 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have a winnebago sightseer and I'm burning up. The lines running from the engine to the heater under the bed put off an awful lot of heat. Is there a cutoff valve or can I install one? How is it pumped?or does it just use the process of hot water rising?
wolfe10
Posted: 07/26/08 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
What chassis?
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
blknomad
ferrum va
Posted: 07/27/08 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Pretty sure its a p32
Lar's
Traverse City, MI
Posted: 07/27/08 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Mine has a turn knob on the dash that shuts off the circulation to the rear. If not, a valve could easily... well sort of... be installed along the pipe line someplace. Look for the knob next to the rear fan knob, it should be there. Hope this helps.
Lar
Sunflyer
JP GC Limited
Kayaks/Bikes/Hiking Shoes
emmmw
Virginia
Posted: 07/27/08 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Our Itasca Sunova (same as Sightseer) has a switch on the dash called coach heat. Switch it off, and no more heat! A wonderful device for winter travel.
summerwinds48
Posted: 07/27/08 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
My 94 Itasca is set up with a heat system under the bed. THere's a switch at the driver's instrument panel that lets me select rear heat high, low, or off. THe system uses the hot radiator coolant, and the switch activates a valve and fan control.
DM
wolfe10
Posted: 07/28/08 06:43am Link  |  Quote  |  Print  |  Notify Moderator
And you can always cut the hose and install a ball valve with hose barb ends as a backup that WILL shut off water flow.
Clay L
Sioux Falls, South Dakota
Posted: 07/28/08 09:15am Link  |  Quote  |  Print  |  Notify Moderator
I just checked my MotorAid system and I see no evidence of a valve. The dash switch activates the fan (High-Off-Low) but the water appears to circulate all the time.
It goes through the heat exchanger on the water heater and then through the rear heater core which is encased in a sheet metal housing.
The coolant is pumped by the engine water pump.
You might see if there is any way to insulate the lines carrying the coolant in the area of the bed.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
ottocontrol
Elburn,IL
Posted: 07/28/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
DM
Same here on our 35U suncruiser. There is a switch on your dash and I bet you it's on. It's called motoraid and it's great in the winter. In most winter driving you don't have to fire up the furnace while under way.
ottocontrol
Elburn,IL
Posted: 07/28/08 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Double post
