SWMO
Southwest Missouri
T bone I probably didn't word that as I intended. My reason for using the "might" was because its always possible that the welder was inexperienced. I didn't mean to imply that the process itself was bad.
2002 Ford F350 Crew, LB, DRW, 7.3L
Jayco Designer 34RLQS
Wherever I happen to park
You said it was heavily loaded
If I had money to bet.. I'd bet it you were kind of "Way over the max GVW" for that trailer. and thus the manufacturer will not (nor should they) pay anything.
On the other hand. Have the weld shop take a good close look at the break. One hopes they know what a "Clean fresh break" looks like (That would be overload) and what "Manufacturer Defect" looks like... I mean.. I do, and I'm NOT an expert.
Deen
Vancouver, WA
T_Bone wrote: Hi TDI,
I'm a 28yr AWS CWI (certified weld inspector), neuclar grade, AWS certified weldor with 33 different certs, ASHREA Engineer for 25yrs, and most of what's been posted in this thread is just the wrong info. I've certified thoudands of AL weldments at full tensil yield.
Post some pictures and I'll give you my best "net" guess as too why.
 Sounds like my son, even down to the nuclear grade and inspector/trainer! Only he's not old enough yet to have that much exp. He learned a lot in the Navy.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
TDInewguy
Minneapolis, MN
Ok, here are a few photos of the break.
Thoughts??
SSSStefan
2006 Chev 2500HD - Crew Cab D/A
2005 VW Passat TDI wagon - tow vehicle for the pup!
2005 Fleetwood Allegiance
The most important thing you will ever do - www.claybe.com
CHV_FRK
Black Jack, MO
I would bet that you were overloaded on the tounge, probably over many times and the stress finally took it's toll. If you can't weight the tounge weight use your truck as a guide. 10% of your trailers GVWR is the max you want. Add that weight with someone and/or some stuff that you can add on the on the tailgate. Measure how far the truck drops and just make sure that when you load the truck up you don't exceed that drop. Good luck with getting it fixed.
Dana and Natalie
2008 Chevy Silverado 3500HD LT DRW CC LB 4x4
2008 Jayco 35RLSA 38'9"
CJW8
Arizona
Thoughts? Yes
1. What was the tongue weight when it broke?
2. What is the Trailer GVWR?
3. What was the trailer GVW at the time of the break?
I am not an engineer but that just looks kinda light weight for a trailer tongue. That looks adequate for a snowmobile or small boat trailer with no more than 150 lb tongue weight.
2004 F350 PSD FX4 SB CC, Banks Cold Air Intake
18,000 Superglide
2003 37SP Forest River Sierra Toyhauler
2008 Polaris RZR
RJsfishin
Winston Or.
I think Aluma should be ashamed of using 2x3 instead of 3x3 tube. Trailer couplers come in 2 1/2 and 3 inch. I have never seen a 2 inch coupler. What did they do, put shims to get down to 2 inch. How cheap could they get ? My little 16 ft boat trailer has 3 inch tube. Most all trailers of any larger size have at least 3 inch.
But, just as long as you know that the trailer had too much hitch weight, sometime in its lifetime,...if not when it broke.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
TDInewguy
Minneapolis, MN
There were 4 tubes inside of the of the 2x3 tongue to strengthen it, if you look really close you can see remnants of it, again they broke too.
As for weights, I'm calculating that now - I know exactly what I put in the trailer, and will be adding it up to get an answer of the weight.
SWMO
Southwest Missouri
I think you have to suspect an overload, not necessarily on the axles, but on the tongue.
CJW8
Arizona
Yes, I can now see the inner tubes. They don't add as much strength as it seems depending on how they are bonded (welded) to the outer tube.
