RV.Net Open Roads Forum: Travel Trailers: outdoor receptacle foam rubber?
 > outdoor receptacle foam rubber?
paedbo
ct
Posted: 07/26/08 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
Ok so my TT's walls are gutted and I'm redoing the electrical. the 110v pretty much stayed the same except i moved the outlets around on the walls to better accomodate the layout, with one exception. I relocated the city water inlet. This left me with a hole in the aluminum siding. So I added an outdoor electrical outlet. My question is how good is the foam gaskets for sealing? Would it be more water tight if i used butyl tape and caulk in place of the gasket?
Thanks
Golden_HVAC
Fulltime, CA, USA
Posted: 07/27/08 12:29am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Yes you can use the waterproof caulking instead of the foam gaskets.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
nny12972
NY
Posted: 07/27/08 05:52am Link  |  Quote  |  Print  |  Notify Moderator
The foam gaskets seem to work on many thousands of Ts.
I use the same double-side dense closed-cell foam tape used to attach auto emblems and logos by the auto mfgs. Works like a champ, doesn't hold H2O, doesn't discolor, and doesn't ever need replacement. It has a gray factory edge which can be painted to match, too.
When I installed my electrical hatch mod---my solar, phone, sat., & cable in one locking hatch, which is in the back of an overhead cabinet, I used a 5/8" thick closed-cell gasket trimmed to fit in the hatch door groove....no leaks in 4 years.
J
TXiceman
(Near) Houston,TX
Posted: 07/27/08 06:58am Link  |  Quote  |  Print  |  Notify Moderator
I would bed in the butyl tape and caulk to insure a good seal.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
paedbo
ct
Posted: 07/27/08 09:20am Link  |  Quote  |  Print  |  Notify Moderator
thanks guys butyl + proflex it is.
