2blackdogs
Anywhere we stop but home is New Mexico
We have to defrost our Dometic fridge about every 2-3 weeks. I do not think that is normal. I was checking the door gasket at the top of the door. with the freezer door open you can see that the one corner of the fridge door gasket does not seal. You can even see the inside light is still on. If I give it a little more of a push to close the door the seal is tighter and the light goes off.
Does everyone have to close the door and then give it a little push ?
Or is there a simple fix for this ?
Bob
Scarface56
Appleton, Wisconsin
We give ours a little extra push to make sure it is locked. In your case I would just replace the seal. I'm sure you can get one from Dometic.
Just Me & DW
2008 GMC 3500 SLT DRW Diesel
Pioneer AVIC D3 GPS Nav/Stereo/backup camera
2007 276RLS Cougar 5th wheel by Keystone
Scooter Buddy 125
17.5 Crestliner Boat
For those of us who fought for it, freedom has a flavor the protected will never know.
XTENTER
MN
I agree with Scarface, it kind of sounds like your gasket might be worn out. Dometic has a web site that's fairly easily to navigate. Good luck.
Chris,Charlene,Amanda and Samantha
Maggie (Lab/Huskey mix)
02 Ford F250 SC W/6.8 V10
98 Prowler 21L5B 5'er
Reese 15K
Glen41
North Texas
Yes, unlike the one in your house, this one has a real latch. The little click sound when you push it is a good thing. It lets you know it is really shut and will not fly open when you go around the first corner. Don't ask how I know
Fun is that stuff that happens in between mistakes.
2006 Chevy 3500 D/A DRW Prodigy, AirBags, CoPilot, EarPlugs
34 ft River Canyon with most of the pieces still attached
RedRam
Moved from the smallest county in Texas
2blackdogs,our is the same way,when we close it we just give it a little push but now it's working a lot better.Wife had the same problem with defrosting but everything is a lot better.
2blackdogs
The fridge is less than a year old so I don't think the seal is worn out, maybe a defective seal ?? It seals except right at the corner where it lacks about 1/8" of sealing unless I push on the door. I wish there was a adjustment on the plastic latch that holds the door shut.
Bob
F-TROUP
VISALIA, CALIF
Try a little film of patroleum jelly around the seal. Just apply with your finger, it worked on our fridge at home.
bdougt
Now Louisiana, Eventually Michigan
I have a constant battle with DW on our door.
CLOSE AND CLICK
CLOSE AND CLICK
CLOSE AND CLICK
CLOSE AND CLICK
I think she refuses to CLICK, just to annoy me.
Brian, Donna, and Ted the dog.
2006 Dodge MegaCab 2500 Laramie 4x2 CTD 48RE 3.73 gears
Firestone AirBags - 16K Reese with Slider
2006 River Canyon 34KSTSO - TrailAir Pin - XPS RIBS 245/75/16
Rob_NC
Walnut Cove, NC
bdougt wrote: I have a constant battle with DW on our door.
CLOSE AND CLICK
CLOSE AND CLICK
CLOSE AND CLICK
CLOSE AND CLICK
Could it be that she's getting back at you for leaving the seat up?
I have the same battle but with my kids.
