RV.Net Open Roads Forum: Folding Trailers: Can Coleman lamp be used inside pup?
 > Can Coleman lamp be used inside pup?
Mike Up
NW Indiana section of Chicagoland
Posted: 07/27/08 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know about liquid gas but the outside high pressure propane stoves, grills and laterns seem to have higher pressure gas output to compensate for the outside wind. More pressure, means more flow through the same size orfices. Being more flow is present, I would have to think that there's excess flow and not complete combustion, most likely producing a lot of carbon monoxide. High pressure propane is needed outside but could produce the extra CO, while low pressure (on your inside stove) most likely produces just enough flow for complete combustion, although even these can produce enough CO to be dangerous. That's why heating through the oven or stove is always a bad idea.
Battery powered laterns are what I use inside my tents and I use the propane laterns outside the tent.
Have a good one.
2008 Eureka Copper Canyon 1312
13'x12' Tent
2007 Starcraft 2406 Exterior
2007 Starcraft 2406 Interior
2008 Ford Explorer Sport Trac 4.6L V8 4X4
292 Hp, 300 lbs torque, 7000 lbs towing, 730 lbs hitch
Tow-N-See Convex Mirrors
MrPressure
Posted: 07/27/08 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
They didn't have air bags or seat belts years ago, but we all wear em now!
* This post was edited 07/27/08 04:17pm by MrPressure *
Klohey
Kanata, Ontario
Posted: 07/27/08 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone for their responses.
I've looked at a dozen or so battery-operated lanterns, some of which even have compact flourescent bulbs. I've hesitated to purchase any of these because I am attempting to find a lamp which is "easy" on batteries.
There are several models which have a crank to charge a rechargable battery. Anyone out there had any success with one of these?
TV: 2006 Hyundai Santa Fe
Pup: 2007 Coachmen Clipper 1070ST
Favourite Campgrounds: Lake Superior Provincial Park; Chutes PP; Sharbot Lake PP; Rainbow Falls PP; Neys PP
colo4nu
Woodland Park Colorado
Posted: 07/27/08 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
We use a wind up lantern, flashlights, and even a radio. We have had them for 3 years and haven't had any problems.
2007 Starcraft 14RT
Beacher
Long Beach, CA
Posted: 07/27/08 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
If you're looking for "easy" on batteries, consider LED's. You might want to retrofit your PopUp's ceiling bulbs with LED replacements. Also, Coleman, and others make LED lanterns that put out pretty good light and last a long time on a set of batteries.
That being said, I also own one of those battery powered remote controlled florescent bulb retro-looking Coleman lanterns. It lasts about 15 hours on low with one set of batteries.
Moose60
Southern Tier, NY
Posted: 07/28/08 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
The Coleman rechargeable I mentioned earlier will run at least 15 hours with both bulbs. I assume it will run longer with only one bulb. It recharges AC or DC and both charging cables are included. We use it even when we have electric hook ups because it also acts as our "bedside" lamp.
pete42
Jamestown, Ohio
Posted: 07/28/08 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
mike4947 wrote:
Way back in the olden days with out first couple of PU's we used both a Coleman Lantern and their Mushroom Coleman fuel catalytic heater in the campers.
BUT we fired them up outside and brought them in once they were burning correctly; and left plenty of ventilation open.
Likewise I too used a catalytic heater and lantern,
that was back in the 60's I'm still here.
We made sure there was plenty of ventilation.
PETE
springoflife
Butler, PA
Posted: 07/29/08 06:40am Link  |  Quote  |  Print  |  Notify Moderator
We have This Coleman Rechargable Lantern, and it's awesome! Bright Light output, Loooong battery life, no fumes, no heat, no flame, Kid-Safe.
