RV.Net Open Roads Forum: Fifth-Wheels: trailer saver air pressure
 > trailer saver air pressure
sanddunesaddict
Las Vegas
Posted: 08/10/08 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
I dont even have an alignment mark??
Im going to call TrailerSaver
Navychop
Fairfax, VA, US
Posted: 08/10/08 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
It's a color band sticker on the shocks. The shocks are optional. Do you have 2 shocks on the sides, in addition to the 4 air bags?
2004.5 Dodge 3500 Laramie Quad LB SRW CTD 48RE 4.10 4x4
97 30' Coachmen Royal TT traded in April '08 on a
2008 Keystone Challenger 35CKQ fifth wheel
Air Safe 25K air hitch
Kipor 3500Ti (avoid- no support)
fullautodave
Northwest Arkansas
Posted: 08/10/08 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
Air pressure won't change, hitched or not.
2009 Mobile Suites TKSB3
2008 Ford F-450 Superduty
2000 Jeep Wrangler toad
Dennis M M
Geneva, IL
Posted: 08/11/08 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Our pin weight is 3,580. I run the Trailer Saver right around 60 PSI. That puts the mark just above the hitch frame.
BTW Dave, you need to take the pressure off before you unhitch or the hitch head will fly up when you pull away and can be damaged. I back in until the pin is in the V on the hitch head, then bring the head up (with air pressure) to contact the pin box, then back it in the rest of the way - works like a charm!
And I agree, best hitch on the market for my money
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'05 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro;
Optima Batteries
Matt & Carol
Fulltiming USA & Canada
Posted: 08/11/08 07:06am Link  |  Quote  |  Print  |  Notify Moderator
It's going to depend on your pin weight. We run 90 psi to take it to the mark.
Teton Frontier/FL 60
BruceStarkey
Ontario, Canada
Posted: 08/11/08 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Navychop: There may be some confusion here as you are referencing an AirSafe pedestal type hitch with 4 air bags and shock absorbers. While the O/P is enquiring about pressures related to a 32BH Trailersaver hitch that is a platform type, front hinged and supported by 2 airbags at it's rear, commonly without any shock absorbers.
Your type of hitch has the pivoting head and it's beam mount moving up and down within four posts with slider plates, four supporting airbags, one under each corner of the beam with shock absorbers controlling rebound rates.
Today is just the tomorrow you worried about yesterday!
'04' International 4400 LoPro 310Hp/950FtLbs 10Spd Harley/RV Toter
'05' Mobile Suites 38RL3
'01' Harley Ultra in the bike barn.
sanddunesaddict
Las Vegas
Posted: 08/11/08 09:56am Link  |  Quote  |  Print  |  Notify Moderator
No mine has 3 air bags and 1 shock.
I think you have a different brand hitch.
Navychop
Fairfax, VA, US
Posted: 08/11/08 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, my bad. I looked at both brands before going with AirSafe- got the names mixed up. My apologies to all.
texatDurango
North Texas
Posted: 08/11/08 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
sanddunesaddict wrote:
I have the 32k 6k pin Trailer Saver on my c6500.
I was wondering what pressure the bags should be at?
Thanks
I agree with a few others in that there is no "Correct" pressure.
I have the in-cab gage where I can release air or add more to the bags while driving and will quite often release pressure when on bouncy roads because the trailer starts porpoising too much and it actually makes towing worse.
I usually fill the bags to around 45psi THEN hitch up which puts me pretty close to "the mark". Sure is easier and quicker filling the bags without all the weight on them.
I would suggest trying different pressure settings and see what is most comfortable to you.
2006 Duramax Diesel 1 ton dually tugging around a 2006 Mobile Suites 36TK3 #2609. Retired and just travelling around now and then seeing the sights.
Rockfarmer
Louisville, KY
Posted: 08/12/08 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
I also agreee that there is no "correct" air pressure. It depends on how much your pin weight is. Add air to get the mark 1 - 1.5 inches above the base. Sandunesaddict, if you don't have a mark, you do need to call Hensley.
Rockfarmer
2006 GMC 3500HD crew cab/long bed/dually (Duramax/Allison)
2003 Cedar Creek 33RLTS
Prodigy b/c, Trailair, and Trailersaver
CCRVC #134
