RV.Net Open Roads Forum: Drilling Corian Desk Top - Update, job done!
 > Drilling Corian Desk Top - Update, job done!
wilpower
Punta Gorda, Fl
Posted: 07/27/08 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
I need to drill a hole in our Corian desk top. It needs to be about a 1" - 2" hole, to pass wires etc.
Does anyone know the proper procedure for drilling Corian? Any special bit needed, or just regular hole bit?
See my last post for update.
* This post was edited 07/30/08 05:20pm by wilpower *
Wil & Cyndi & Einstein (African Gray)
FMCA # F262386
Dick_B
Palos Heights, IL USA
Posted: 07/27/08 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
A typical wood drill bit should work. Corian is really plastic and can be handled as such. Just keep the speed down.
I cut a hole in my corian countertop to add a water filter. Easier than I thought.
Dick_B
2003 SunnyBrook 27FKS
2003 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Jamesrpm
Oregon Coast
Posted: 07/27/08 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Use a sharp carbide tipped hole saw.Let the bit do the work don't force it.
___________________________________________
I plan on living forever , so far , so good
Trailer Trash 2
Santa Fe Springs, CA
Posted: 07/27/08 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
I just drilled a 1/2" hole in a piece old 1/2 Avanite which is the same as Corian, with a standard HS drill bit, I had no splintering or blow out, I used steady presure and medium speed.
Your counter top for your desk might not be solid Corian it might be a layier over fiber glass, or laminated to plywood, you can use a standard hole saw to drill your hole then get a trim cover from a good cabinet hardware store.
Don & Georgia
AKA: Trailer Trash 2
Real trucks don't have spark plugs.
1996 Ford F-350,Clydesdale, 7.3 Turbo W/Banks
Pulling a Super Fine Montana 2980RL
Jaseds
NE TN.
Posted: 07/27/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
The correct way is tape the area to be drilled and use a carbide hole saw as stated.Drill slowly.If you can clamp a piece of wood on top and bottom to help keep from flexing and possibly cracking.
Have A Nice Day
mgh122
PA
Posted: 07/27/08 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto 42 years carpentry experience.
Mike & Peg
Aint' life grand!!
'05 Discovery 39S
'04 Grand Cherokee Freedom, M&G, Roadmaster Sterling
http://discovery-on-the-road.blogspot.com/
Zeus the Wonder Dog
"makes you wonder doesn't he"
swp5767
Royal Palm Beach, FL
Posted: 07/27/08 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Tape and hole saw.
Bumpyroad
Virginia
Posted: 07/28/08 04:50am Link  |  Quote  |  Print  |  Notify Moderator
be sure to buy your trim cover first so the hole is the right size.
bumpy
rvhank
North America
Posted: 07/28/08 06:05am Link  |  Quote  |  Print  |  Notify Moderator
I installed a soap dispenser on the kitchen counter. Taped the spot, bought the hole-saw at Home Depot and used their lubricant. Slow and easy.
'03 Adventurer 33V
'03 Saturn ION w/Ready Brake
Hank & Darcy & Bear
Rich D.
New England
Posted: 07/28/08 07:34am Link  |  Quote  |  Print  |  Notify Moderator
bumpy
They are available at Staples or other office supply stores and come in several sizes both in metal and plastic. Colors are available. True Value Hardware here stocks them as well. They allow a cord with a plug to pass through then have a cover to reduce the hole size.
Rich D. Wanderlodge LXi 43'
