speediq99
Arizona
Hello everyone,
We have had 2 Class C MH and 1 Trailer w/ a mix of refrigerator type. All of them 1-5 yrs old at most. In all instances, the bottom part of our fridge would 'barely' be cold enough to keep milk from spoiling. The top would freeze foods after 2-3 days running.
All these units were relatively new, coils etc... very clean yet cooling w/ propane left a lot to be desire. Our most recent unit, a Dometic on a 2005 Class C, barely has enough cooling power to keep water cool in a hot summer day.
Is this your experience ?
Mike
HedoTravelers
Rochester, New York & Jamaica, W.I.
We use a small battery operated fan in the refer to keep the air moving ( CW has them). Ammonia style refers remove the heat from the unit as opposed to cooling the air. Keep the door closed as much as possible, and the more stuff inside the fridge, the easier it is to keep it cold.
Respect,
Brent
TV ~
Cadillac Escalade EXT, Prodigy BC, Reese Pro Series SC
Rigs ~
Starcraft Travelstar 21RBS, Alcan Traveler Tent Camper
"Where ever you go, there you are"
dbbls
Missouri
There is a thermostat on the fin in the back of the refrigerator. Slide it up (I think) to make it colder.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
movein
NC
I think it needs to be level to work well too right? Anyway, I haven't had an issue so far. I have/had norcold in 2 different campers and no problems in either.
Admiral
Lodi, Ohio
No, all of my rv fridges, (7) operated at similar temps to my home fridge, about 42 degrees no matter what the outside temps are. I use one of those circulating battery powered fans inside my fridge so the temps will stay uniform on all the shelves.
2004 Damon Daybreak 2960F
05 Honda Element LX
In a democracy two wolves and a sheep can vote on what to have for dinner.
speediq99
Arizona
I will give the fan a try. The thermostat is already all the way up.
Mike
mockturtle
Northwest
RV refrigerators are a lot more reactive to ambient temperatures than the kind we have at home. In hot weather, we freeze blue ice packs and keep them in the fridge during the day, sticking them back in the freezer at night. It helps a lot. It also matters which side of the coach (or trailer) the sun is on, especially in the afternoon. Window awnings help, too.
Husband: Derek
Dog: Bucky
RV: 2000 Aerolite 19RB TT
TV: 1996 Chevrolet Blazer 6 cyl. 4WD
This car used to be our toad, now is our TV!
javaseuf
Southern Cal
And actually, ALL refrigerators, whether absorbsion or compressor, operate by removing heat from the box. Basic principle of refrigeration.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Jerrybo66
AZ
Being in Az. I also feel your pain. I had the same problem until I took the cover off the top of the roof vent and found that the insulation wasn't secured, it dropped down and covered the vent channel. I also installed a 12 volt fan from Radio Shack to blow air over the outside coils and up the vent to circulate more air. I tapped off 12 volts behind the access panal and put a manual switch to control the fan. If I want the refer on during the Summer I shade the cover and run the fan. It helps a lot.. Good luck. Only 4 more months 'till camping season.....
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
Opie431
Bellevue, MI
With ours parked in the sun at 89 degrees I put an indoor outdoor thermometer inside when I turned it on electricity so I would know when I could start loading it. In four hours it was down to 42 degrees and at six hours it was 36 degrees.
When I opened the door to load it, the temperature went up right away.
