RV.Net Open Roads Forum: Is the diesel engine's reign as king of torque soon over?
Search only in Tow Vehicles
 > Is the diesel engine's reign as king of torque soon over?
mtlogger
Montana
Posted: 07/29/08 04:50am Link  |  Quote  |  Print  |  Notify Moderator
Westport is owned in part by Cummins and yes I have a Uni and my son has a gasser Uni which is in the conversion process. They just can't be beat for heavy backwoods hauling. I had mine up in Glacier the other night, bear watching - everyone else needs to look up to us!
Matt J - 1956 416 Unimog w/32ft Jamco and two mules; Unimog 1750L camper in Guatemala
Bert - '08 Dakota 4.7, 19ft Airstream
My best friend Wolf died this morning, 16 Nov
pronstar
The LBC
Posted: 07/29/08 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
lesmore49 wrote:
I'm no mechanical or electrical engineer, but I've often wondered about making the railway system, diesel electric engine technology 'streetable' .
That's called a series hybrid, and the Chevy Volt uses this technology.
Turtle n Peeps wrote:
I've never seen so many half truths and lie's in a long time!!!
Alky that is mixed with gasloline for 150 octane? What the????
I wish!!!! When I was racing with the stuff it was around 113 to 115 or so. Is this magic alky of some sort??? Maybe they ment 150 proof?? LOL
Pure ethanol has a RON of 129...mixing it with gasoline lowers the octane rating, but used alone as a fuel it has very high octane.
2007 Dodge Ram 2500 CTD 4x4/QC/LB
2008 Stellar 23' Toy Hauler
jmramiller
Dallas
Posted: 07/29/08 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
When the big rigs have run this combo for a few years then I might become a believer. Until then...
2006 2500HD CC SB 4X4 Duramax/Allison
Prodigy/16K Reese/265E Tires/Bilstein Shocks
RM Active Suspension/RDS 60gal Toolbox combo
2008 Big Country 3490BHS by Heartland
Hannibal
Gas Station
Posted: 07/29/08 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Then what? You got an ISX 600 in that Chevy?
'05 2500HD Dodge 5.7L Hemi 5spd auto/3.73 SLT. 95k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins
'07 KZ Jag 28JFSS.
pronstar
The LBC
Posted: 07/29/08 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Ethanol still has a lower energy density than gasoline, and significantly less than diesel. So while you can make great power with it, you have to burn a LOT of it to do so...so you have to weigh the per-gallon cost advantage (if there is one) against the fact that you will burn so much more of it.
dirtbag3
Hesperia Ca.
Posted: 07/29/08 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I sure hope those MIT guys read this forum.
Sure would'nt want them wasting their time after consulting with you boys.
F350 V10 4x4 CC DRW 160k
05 25' Stellar
jmramiller
Dallas
Posted: 07/29/08 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Don't I wish.
What I meant is that the diesel engine has been very successful in a very demanding role, powering the big rigs. If a 7L gas engine can successfully fill the role of a 11L diesel engine over time (and many millions of miles) then I might be willing to take a look at a 1 ton truck powered by the same technology. Until then I will stick with my diesel.
wilber1
Abbotsford B.C. Canada
Posted: 07/29/08 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think they are waisting their time, the idea of being able to give an engine a large increase in power and torque on demand is a good one, akin in some respects to nitrous but as far as making a 5 liter gasser put out that kind of power and torque over a long period of time for a serious tow vehicle, I'm skeptical. It will have to be designed as one tough engine from the crankcase up, like a diesel.
"Never trust a man who has not a single redeeming vice" WSC
JPhelps
SE of Monkeys Eyebrow & Possum Trot
Posted: 07/29/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
When asked what the power potential of a 5.0-liter turbo V-8 with ethanol boost would be, Cohn suggested 500 horsepower with peak torque of 700 pounds-feet. Actual figures, of course, may change following durability and emissions testing.
The most significant part of that paragraph is: "Actual figures, of course, may change following durability and emissions testing".
high compression (12:1 or 13:1) and turbocharged, with boost pressures around 35psi
They talk like this thing will be cheaper than a diesel to produce. Cylinder pressure (BMEP) is what makes power and the smaller the displacement the more pressure and/or rpm you need to make the power, and both of those are expensive to make reliable over lots of miles. And if you want it to go 200,000/300,000 miles towing 10,000/15,000 pounds it will be really expensive.
I don't see a savings here either in initial cost or fuel mileage, that is is if you really want to tow something.
But it is definitely worth researching, as long as I don't have to pay for it.
JPhelps
Posted: 07/30/08 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins has a 472HP/942TQ QSB-5.9 available right now if you need one. Of course it is a diesel, for a boat.
http://marine.cummins.com/attachments/pu........s/Recreational%20Inboard/QSB/fr92132.pdf
