Getting to be tire buying time. Due to road hazzard damage, I'm looking at new tires, but only need 2. I had thought of changing to LT's when I needed new tires. Anyone know the good, the bad, and the ugly of running a pair of P's on front and LT's on the rear??
I know the proper answer is do not do it. And I would do it today.
But, back in the day (1994) I was in high school, dumb and young. I had an old 1967 Dodge Polara that had 3 different sized tires on it, two of which were bias-ply tires. I had that thing up to 85+ mph on the way to concert with 3 friends inside (actually one is my wife now!). It was a dumb move, and luckily nothing happened........but it could have.
If money is really tight you probably could do it without problems....but I would not tow with the mismatched (P-LT) setup.
-2006 Nissan Armada LE 4x4
-2007 Coachmen 19FLB SE
-2007 Regal 1900 w/ 4.3 EFI Volvo
Supercharged wrote: 4-in-a-fiver and my statments make the same amount of since.
my wifes 1500 CC 4x4 chev has Bridgestone P radial tires on the front and BFG LT radial load range C on the rear. Absolutly no problems with handling when max loaded or empty. As Donn says radial/bias ply mix isn't recommened for very good reason.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
I dont think I would put a P on the drivers side and a LT on the passenger side, but P on the front axle and LT on the rear axle shouldnt be a problem.
All things are for that 'bad' or 'worst' day out there.
By the time your skidding sideways and needing all of whatever safety margin you
can muster, there is no time to go back to the store for the right parts, nor
time to readjust correctly. Either it is there, or isn't....
-Ben Picture of my rig
Do you have a 4X4 like (it seems) most people here? If so, read and follow the instructions in the Owner's Manual about tires. Every 4X4 I have ever owned has stated something like "All tires MUST be the same size, type, load range, and tread pattern".
If you don't have a 4X4, never mind.
CM1, USN (RET)
'94 Dodge 3500 4X2 CTD, Std. cab, LB, 5 speed, 4.10 LS diff., Jacobs Rambrake, 273,000 Miles
'99 Monaco McKenzie 32' triple slide
'95 Tioga 29H Ford-based Class C
Daily driver: '06 Jeep Liberty CRD
Towed: '06 Jeep Rubicon Unlimited
mowermech wrote: Do you have a 4X4 like (it seems) most people here? If so, read and follow the instructions in the Owner's Manual about tires. Every 4X4 I have ever owned has stated something like "All tires MUST be the same size, type, load range, and tread pattern".
I agree with mowermech on this issue. If you have a 4x4, I wouldn't mix P type with LT type tires. If you have a 2wd, it shouldn't matter. I remember back when I was a kid and 4x4 wasn't as common, it was common to see different types of tires on the back of 2wd trucks.
2005 Surveyor SV-291 Tows smooth as silk!
1995 Dodge Ram 1500 Laramie SLT 4x4 5.9L V8 low miles, It ain't pretty, but it's paid for!
