RV.Net Open Roads Forum: Class A Motorhomes: A/C Air filters
 > A/C Air filters
Fevermeister
La Vergne TN
Posted: 07/28/08 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
I have recently purchased a 1994 Newmar Dutch Star 34 ft Class A motorhome. I have been unable to determine where the air filters for the A/C units might be. Both units appear to be connected to the same duct network. there are circular vents in the ceiling. every other one appears to be an intake. there is no service plates in the ceiling and I was unable to see anything on the roof. Any Ideas?
peavyjay
Ontario
Posted: 07/28/08 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
I think they are behind the intake.
wolfe10
Posted: 07/28/08 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
They will be serviceable from inside the coach. Look for the air return directly under the roof A/C units.
Tell us the brand and we can give further instructions (or look in your A/C manual).
Brett Wolfe
1993 Foretravel 36' U-240
Cat 3116, Allison 3060
Caterpillar RV Engine Owner's Club: www.catrvclub.org
TMitchell
Punta Gorda, Fl.
Posted: 07/28/08 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2004 DSDP. On mine you remove the inside portion (open spoked piece) of the intake vents. The inside pieces are held in place at the very center, so put your fingers in close to the center and pull. They should pop out. Pull close to the center on them, to avoid breaking them. They are hard to find if you have to replace them. I have had mine out many times without any problem. There is an approximate 5" diameter washable filter in each one. I clean them in the sink, let them dry and reinstall them.
Tom
Tom,Pat and Buster the Boston Terrier
2004 Dutch Star 3807 Spartan 370HP
Jeep Grand Cherokee
tropical36
Southwest Florida_USA
Posted: 07/28/08 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
yep....they are inside the intake grilles measuring about 14x7.5 inches...made out of foam and easily cleaned with soap and water...then wring it out and re-install.
The grilles are usually opened by squeezing a couple of tabs which then hinges down exposing the filter.
This is the basic setup for mine which has two roof air units.
You don't have basement air of some type do you?
* This post was edited 07/28/08 04:52pm by tropical36 *
"We are often so caught up in our destination that we forget to appreciate the journey."
1998 36ft. National Tropi-Cal, with a tag axle and one slide, on a 1997 P32 Chevy chassis....7.4 Vortec Engine
barnaclebill
Atlanta, Michigan or towards the sun
Posted: 07/28/08 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
They are inside (seen from the outside of vents) of the return air vents on my Mountain Aire diesel pusher, up in the ceiling. I have washed them many times and reuse them over and over. Perhaps the previous owner tossed them?
TMitchell
Punta Gorda, Fl.
Posted: 07/28/08 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Newmar motorhomes are not like yours. They use multiple output and intake vents throughout the motorhome. I think I have approximately 12 to 14 total vents in the ceiling. They do not have just one intake grill per air conditioner. Their system is suppose to distribute air more evenly throughout the MH and be quieter while doing it. I don't know if it is any better then other methods.
Tom
chastho
arkansas
Posted: 07/28/08 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Tom
I know most Mhs now have the system you are talking about but on a 1994 model? I didn't know they were using it back then.
zsr22
Atlanta, GA
Posted: 07/28/08 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
If my filters are clean, what would cause my AC to blow so weak in the rear compared to the front?
(I know the front is larger for a reason but the rear "high" fan setting sure isn't anything to write home about)
Zack
1998 Holiday Rambler Endeavor 36WGS
Front Row Talladega Infield | ol' Kegerator | Our UGA Tailgate
dougrainer
Carrolton
Posted: 07/29/08 06:06am Link  |  Quote  |  Print  |  Notify Moderator
The Passenger side air ducts are the filtered side ducts. If your rear AC in NOT blowing the correct volume of air, On a Newmar, there is supposed to be an extra gasket installed when the AC is installed to direct all the cold air into the ductwork. From the age of your un it, I will bet that AC has been replaced and whoever installed it did not install the extra gasket. This failure to install the extra gasket (ALL NEWAMARS use this extra gasket) is quite common for installers that do not know how Newmar installes the AC units. Without that extra gasket, the air does NOT flow into the ductwork correctly. Doug
 > A/C Air filters
