RV.Net Open Roads Forum: Travel Trailers: Broken Awning Knobs..
 > Broken Awning Knobs..
Hornet28BHDS
Parker, PA
Posted: 07/28/08 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
I think you can make that a DIY project. Call you dealer and ask them if they have any of those knobs in stock.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
javaseuf
Southern Cal
Posted: 07/28/08 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
Nutsert tool
They also have the replacement knobs as well.
Complete list of parts.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Campinfan
Washtenaw County, Michigan
Posted: 07/29/08 08:09am Link  |  Quote  |  Print  |  Notify Moderator
My new awning has as groove in the knobs so I can use the pull down down rod to tighten the knobs. Works great because I tend to forget to tighten those knobs until the awning is all set up.The new awning is an AE 8500 series with the rain dumping piston.
________
2008 F 250 FX4 4WD, V10, 4.10 Tow Command
35' 2007 Crossroads Cruiser CT32SB
Wonderful Wife and 3 small kids
rhondavid
Birmingham, Al
Posted: 07/30/08 06:10am Link  |  Quote  |  Print  |  Notify Moderator
I have issues with one of mine as well. The Knob turns but never loosens. Feels like it entire unit is froze and the bolt head is turning on the back side as it make a popping sound like it is jumping in and out of the hole.
David,Wife,4 kids,SIL,1 grandchild
2003 Ford Excursion Eddie Bauer 7.3 PSD w/3.73 rear end
Jayco Kiwi Too 30T bunkhouse w/triple bunks
Prodigy Controller
Reese Dual Cam HP
Michelin LTX M/S
Topsail Hill Cult Member
alcaudle
Asheville, NC USA
Posted: 07/30/08 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the bolt is frozen to the nutsert. The least resistance is the nutsert to the arm, so the nutsert is turning. That was my case. Cut it off, and install a new one beside it.
Alan, Donna & Savannah
rhondavid
Birmingham, Al
Posted: 07/31/08 05:38am Link  |  Quote  |  Print  |  Notify Moderator
alcaudle, thanks for the advice. Will look into and see what I can do.
