RV.Net Open Roads Forum: Truck Campers: controlling the roll
 > controlling the roll
joemyers
Houston, Tx, USA
Posted: 07/28/08 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
sundowners wrote:
Thanks for the link, I have never heard of edelbrock shocks, is it the same Co that does carbs/manifolds etc.
Nigel
Yes
Joe, Retired & on the road whenever I want, KeepMov'n
2000 Dodge/CTD 3500 DRW SLT+ 6 speed 4x4, 3.54 rear, Jacobs Exhaust Brake
2003 Lance 1121 with all the options plus
1999 Toyota Taco V-6 5 speed 4x4 Toad
luv2skyski
Stockbridge, Georgia
Posted: 07/29/08 05:13am Link  |  Quote  |  Print  |  Notify Moderator
I installed longer bump stops. They made a huge difference. Dave.
1999 F250
2004 Northern Lite 10-2000RR
What do you do when you miss your in-laws? Your reload and shoot again!
hopak
Point Reyes Station, Ca. / Crestone Co.
Posted: 07/29/08 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Timbrens or Ranchos should work. Had a Lance 1030, never had a problem with roll even with only 55lbs in the rear. (02 dodge drw) But I do have the camper pkg.
2002 Dodge,diesel, 3500,4x4,auto/od,ex,cab, 01 Bigfoot 25c 10.5
Mooney
Santa Barbara, Ca
Posted: 07/29/08 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Supersprings work great with roll.
'08 Ford F550, Lariat, Link Air Suspension, Roll-A-Long Conversion, Twin Turbo 6.4, TorkLifts, SuperHitch, "Monster Duty Truckasaurus"
'05 Lance to-the-Max (Sold)1181.
'09 Host Everest
scottz
Big Lake, MN
Posted: 07/29/08 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Rancho 9000s eliminated most of the roll I had.
2004 Silverado 2500HD, Crew-LB, 6L-Gas, 4x4, Air-Bags, Hypertech III, Rancho 9000X/XL, Pirelli Scorpion ATR 265/75-16
2005 Lance 1030, Happijac Tiedowns, Lifeline AGM Batteries
2006 Tritontrailer ATV168 4 place, 2001 Kodiak, 2003 Trailblazer
sundowners
suffolk UK
Posted: 07/29/08 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
Hi
Tooooo many options!!!!!!!
I must order this week to get fitted before our next trip out , I started out with 3 options and every reply has a different solution!!!!
I suppose I should have realised that everyone would have their own "best" solution.
Lets say, would it be a waste of money to buy a set of Edelbrocks??----remember that I really don't want to lift the suspension, I only need to reduce roll.
Thanks for so much feedback on this
Nigel
joemyers
Houston, Tx, USA
Posted: 07/29/08 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
The Edelbrocks will do the trick assuming nothing else is worn. I have been coast ot coast multiple times through all types of terrain and off road with the camper on, with no handleing problems.
Mr. Tree
Cincinnati, Ohio
Posted: 07/29/08 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Some of the roll can be controlled by how you drive the rig. When crossing railroad tracks or entering/leaving a driveway, square the front wheels with the tracks/street so both wheels go over at the same time. Then keep your truck going straight till the rear wheels go over as well Only then should you turn to continue driving normally. This takes a little getting used to but it sure has helped me drive with less rolling.
See you soon on the American Road ?
1973 Ford American Road 11.5' Camper with 500,000 enjoyable miles.
1985 Ford 250HD, 6.9Diesel/4-speed/3.54 limited-slip axle, Supercab, SRW. Consulting forester, Supervisor of SWCD, and NRA Life Member.
A city without trees ain't fit for a dog!
sundowners
suffolk UK
Posted: 07/29/08 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Mr. Tree
We had planned to come over to your side this autumn (fall)/winter to buy a TC, but one turned up for sale here so we don't have that excuse now! but I have a sister in TX and good friends in CAL. so we will get over asap.
Nigel
Fuzzy Bear
Carnation, WA
Posted: 07/29/08 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 2003 3500 SRW that I hauled the AF990 camper with. Heavy camper and a bit top heavy at times. With the Rancho 9000 shocks, rear sway bar and air bags it would still sway. I added the extended bumpstops as already mentioned and that took away the sway. Key is to see what is going on when loaded. For me I would air up the bags to level it out but the overload springs were not contacting the stock bumpstops. The rear axle was swaying on the air bags. Added the extended bumpstops (an inexpensive upgrade at $80 for 4 and can be air shipped unlike a lot of shocks). After that the overload springs had four more contact points and eliminated the sway. That worked well until I added the 20' boat to the back. Then I had to step up to the dually and that really eliminated the sway and pushing that was not fun with single rear wheels. Go with the bumpstops (can even modify your stock ones) then try better shocks.
Doug
2008 Dodge 3500 DRW 4x4 6spd auto. Loaded! Bought it for the bun warmers
01 Artic Fox A990
94 Sea Ray 200 Cuddy
