RV.Net Open Roads Forum: General RVing Issues: Dark Patio
 > Dark Patio
Scott9413
New Orleans
Posted: 07/28/08 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Just wondering how any individuals that own an automatic awning put patio lights on them.
My Seneca 35GS has an automatic awning that is sealed on both ends by the mechanism used to roll it up and down. I have no access to the awning channel that I used on manual awnings in the past.
The Senica has only one exterior light on the awning side located between the entry door and and a slide out. When slide is extended, the light is useless except for illuminating the entry steps and the side of the slide. So far my only solution is to lay some rope lights out on the ground, and I am not pleased with that.
I seriously miss my lights!
Scott
2006 Jayco Seneca HD 35GS
2004 F250 Crew Cab (for sale)
rrbowman
Kennett Square, Pa
Posted: 07/28/08 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
We also have an automatic awning, but we have solved the light issue with two alternate means:
1. We carry a collapsable step ladder that we use to hang our lights from the accessory groove. We use Rollemup straps in the accessory groove, that way we can leave the straps in place when we roll the awning up. Caution be sure to turn enable switch off to prevent the awning from rolling up unexpectantly.
2. We have a set of solar pathway lights that we place in small flower pots filled with local gravel or dirt, we place them around the patio area and they provide a soft glow that is not offensive to neighbors. These require no electricity, they charge during the day and come on at dusk and stay on all night. When breaking camp the batteries must be removed or the lights will stay lit in your compartments until completely discharged. You can either use the flower pots plain or you can decorate them.
Have fun.
HeresLucy
Southeast FL
Posted: 07/28/08 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Does your awning have a flap that hangs down from the roller bar?
Hard to explain what that mean - and I don't have a good picture to show you. Unless you can see in the small pic in my signature. Anyway, if you understand what I'm describing - you could buy some clips and just attach them to the flap area with those. We have a channel, but DH came up with clip idea because it would be easier to take them down. We don't like the channel -- its a bit cumbersome. Our clips are long and silver so on our grey awning you'd probably never notice them at least not from a distance.
Lucy
2006 Allegro Bus 40' DP
2005 Grand Cherokee
Visit Here's Lucy for CG reviews, trip experiences, etc.
tgr2975
NJ
Posted: 07/28/08 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Have you thought about solar powered landscape lights? I would hate to see your awning roll up with the lights attached.
2002 F-250 CC, PSD, SB
2008 Brookside 298 FWBHS
Wherever I happen to park
Posted: 07/28/08 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
I picked up a nylon cloths line at a dollar store, this is a nylon cord which has close pins already on it, and a pair of hooks on each end, intended to be strung up and taken down.
I drilled a couple of holes, put in a couple of "S" hooks a few inches "in ward" from the roller and.. It holds the lights
Should the stupid A&D sensor roll it up in a 0.04MPH wind again.. No damage
lat471
Lebanon, PA
Posted: 07/29/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
Rope lights on the ground.
07 Cameo LXI F35FD3
R Taj-We-Haul
Posted: 07/29/08 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Re- Rope lights on the ground.. I tell my wife and I tell her DON"T STEP ON THE LIGHTS but does she listen? (Actually she simply does not watch her step, never has)
For the folks who suggest using the spare channel in the tube or the flap, the problem is if the awning auto-retracts this makes one mel of a hess as they say, As the lights roll up inside the awning and the cord gets torn up. Not a good thing at all.
This is why I ran a clothsline "inside" about 6" back from the roller tube
That way the lights just hang off the line, If it retracts they keep hanging off the line. Work great
Dustytuu
Colorado USA
Posted: 07/30/08 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Pictures anyone? Would like to see some close up pictures please
2008 dodge 5500, diesel,Laramie cab, pressure pro tire.
2008 Carri-Lite 36SBQ, 4 slides,dishwasher,washer/dryer,2 fireplaces
D & D
Two Schnauzers, & cat
http://s6.photobucket.com/albums/y250/Dustytuu/
Criminals prefer unarmed victims!
HUTCH45
NORCAL
Posted: 07/30/08 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Leave them off.....enjoy the campfire.....(ahem)....
Enjoy the journey....
"HUTCH"
'07 SILVERADO 3500HD 'CLASSIC' DRW - CC - 4 X 4
'07 NEW HORIZONS 35' 5th.Wheel 'MotoMover'
'06 HONDA 106hp.VTX1800 w/'HANNIGAN' Sidecar
"PRIMO" The Boxer
 > Dark Patio
