RV.Net Open Roads Forum: Leaks... How many of you have had them , big or small?
 > Leaks... How many of you have had them , big or small?
Page of 6
LakeN
North Carolina
Posted: 07/31/08 08:23am Link  |  Quote  |  Print  |  Notify Moderator
The Trail Lite in signature does NOT leak. We previously had an old PUP that did not leak and a newly purchased 2003 Jayco that DID LEAK and delaminated. NEw roof installed by Jayco factory and leaks became worse. Thank heavens it was under warranty. I think it went to TT graveyard. A real lemon!!
'08 Toyota Tundra 5.7L with tow package/Prodigy
'09 Heartland North Trail 26RKS
2 campers + 1 spoiled golden retriever, Daisy
cremevette
NE Ohio
Posted: 07/31/08 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Badly leaking window June 2008. Window seal was about 50% loose. It was covered under warranty.
I had a leak over the winter. I swear I didn't leave the bedroom roof vent open, yet it was open maybe an inch and there was snow on the bed. I just made sure the vent was secure.
Now I have a leaky sink. I opened the drawer underneath and there were droplets on the kitchen utensils.
Bathtub leaked into the living room floor. Original dealer hadn't caulked around the tub surround.
I know I didn't pay $75K for an Airstream, but sheesh, I also have a list of non-leak stuff.
Claudia
2007 Keystone Springdale 266 RELLGL - The Brownie Bungalow
2005 Silverado 2500HD, 6.0 - The Mammoth
Nights in 2007 - 30
Nights in 2008 - 48
mecreature
Indianapolis, IN
Posted: 07/31/08 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
I had a leak in the back and on the front.. went over all the seams with dicor. seems to have fixed the problem.. they were small leaks..
Last winter I had water in the underbelly... It rain and then froze a solid sheet of thick ice over the whole trailer.. then it started to rain again and some thawaled. It did not help that we had a 50mph wind blowing the whole time..
seems good right now I am going over everything top to bottom.. might even reseat a couple windows..
98 Skyline Nomad 1950 Compact
2004 Silverado 1500 EXT. 5.3 3.42 Axle 2wd
jorn
Twin Cities
Posted: 07/31/08 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Rules of RV leaks:
1. Your rig probably has a leak. Let's hope you find it soon.
2. Please see #1
2001 Coachmen Leprechaun 314SS (Acquired in July 2008)
Bonefish
Midland, TX
Posted: 07/31/08 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
We must have got a good one. Our Forest River 2004 Wildcat has never had a roof, slide or window leak. We have been in some really serious storms, too. We have only had two small weeping leaks on water line fittings which were discovered on rig up and easily remedied. I generally as a rule check under the sinks and open the panel over the water filter and pump to check for leaks when I hook up the system.
Bonefish
H & E
North Texas
Posted: 08/01/08 04:30am Link  |  Quote  |  Print  |  Notify Moderator
Found the leak. See previous post. Water came out side the tub enclosure where the glass meets the fiberglass along the bottom. The tub enclosure trim on one corner was not trimmed correctly. Hope the silicone I used to fill the gap works.
lotust
Long Island NY
Posted: 08/01/08 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
jorn wrote:
Rules of RV leaks:
2. Please see #1
I think this is the truth. I dont think everyone knows they have a leak untill its too late.
  • 2006 Jayco Jay Flight 27 BH.(paid off :-)
    2008 toyota tundra 5.7L w/tow Off road Pkg. (not paid off)
    Honda Eu2000i
    The wife and the dog Loving Camping!
The Black Pearl
Ottawa
Posted: 08/01/08 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Choice spot wrote:
We had a leak. Took it in, they recalked the whole top and are fine now.
Black Pearl, what are you going to do about your door? We have the same problem. DH worked on it last night, but it's not much better.
My primary door seals well, but the screen door is off by 3/4 of an inch away from the foam seal near the door opening. I had used raid on the door (allot) at a camp site and checked it in the morning. It is amazing just how many bugs are around the door. I then removed the seal that was not touching the screen door and used a thicker seal for the screen door to compensate for the deviance in order to seal the screen door. The seal I bought was not the best (door pops open once in a while) but it was all I could find in the town we where in. The next night there was no bugs in the trailer. I am going to look for a thicker more sponge like seal to replace the make do stuff. Hope that helps...
2004 Trailblazer Extended
2005 22' Sunvalley Roadrunner 210BH
GVRW 4750 - Minus UVW 3360-Minus freshwater 266.56-Minus LP tanks 22.5-ccc 1,100.94
Prodigy Brake Controller
Eaz-Lift hitch
Distribution Bars rating 550lbs
Sway control
Top Pop Rails -3 bikes
4BeachCampers
SoCal
Posted: 08/01/08 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
So far, so good... Happy to report no leaks here... and hopefully never will...lol
1999 Starcraft 21CK
View our Profile for more pics...
surveyorjp
Missouri
Posted: 08/01/08 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
I fixed a leak in our front seam where the rubber roof meets the front cap this spring. Had to reseal the seam with dicor.
Leaks are quite common on RVs I am afraid.
2005 Surveyor SV-291 Tows smooth as silk!
1995 Dodge Ram 1500 Laramie SLT 4x4 5.9L V8 low miles, It ain't pretty, but it's paid for!
Page of 6
