ragrin
texas
What are the advantages/ disadvantages of elect and hyd power for slide outs. I am leary of hyd and also they add extra weight
Jack_Diane_Freedom
Lindsay Ont, and Gulf Coast Florida
Actually as far as I am concerned hydraulic is much better and actually less weight. Only one motor/pump and a hydraulic resevoir. Also much faster and quieter. The hydraulics today are very dependable.
thomasinnv
where ever i stop
i've had both. when my tt was slightly off level, the electric slide bound ever so slightly resulting in a sheared key. the only way to get the slide in was to replace the shear key. luckily i was in town and the hardware store had the right one. if the motor were to have failed there would have been no way retract the slide short of pulling the motor off the screw and hand cranking the screw. on my current hydraulic setup, there is a hand pump next to the motor. if the motor fails then you just pump the hand pump like a bottle jack, easy enough. oh, and i have operated the hyd slide when slightly off level with no problems.
it's all a matter of preferance really. many people will have many opinions.
2000 F-350 Extra Cab SD 4X4 7.3 PSD
2000 Wildwood 28RKSS2S 31' 5ver
Derrick, Michelle, Michaela, Riona and "Bones" (K-9 companion)
We Are Currently Here
my website
Rossey
Appomattox, Virginia. / Rockville, Maryland
I've had both...electric on my previous T.T. and Hydraulic on my current 5er..........no comparison in my opinion. The Hydraulic system is smoother, quieter, FASTER and more powerful, especially considering the fact that I have 4 slides, one of which is very large. You won't be sorry if you buy a trailer with a Hydraulic system.
Gooseneck
Waynesville, NC, USA
My 1993 unit has a hydraulic slide which works great and has never given me a problem. I do have some minor pitting in the rams which is causing insignificant leakage (2 ounces of fluid last year). I suppose someday I will have to replace both hydraulic cylinders but, it is a '93 edition. I've never had an electric version so I can't give an opinion there. Hope this helps and good luck!!
Gooseneck
2003 F350 4DR DRW w/7.3PSD 4WD
Upfitted/Updated Dutchmen 30' 5er
sclark
Minnesota
We have Hydraulic slides and landing gear. Never had any problems with our setup. Seems to be much quicker then the motor driven slides. Good luck with your decision.
2004.5 Dodge Cummins
2007 Wildcat 32QBBS
Pair of Honda 2000 Watt generators
Dandy Dan
Findlay, Ohio
We have had the hydraulic slides and gear driven slides. With the new 5er it has small electric motors with cable driven slides. I was somewhat hesitant but they work excellent and are quick and smoothe. Faster than my others were.
Dandy Dan
dan218b@tds.net
Dan and Lori Branson, Anna 1 (the rescue)
and Beau (waiting at the Rainbow Bridge)
2005 Dodge QuadCab 2500 4x4 Hemi
2009 Open Range 337RLS
RV.Net Ohio Rally Member
JUrban
Delaware
Our Allegro Bus has both. Because we have 4 slides, it appears Tiffin engineers put hydraulic actuators on the passenger side, and electric on the driver side so opposing systems would not conflict by using the same space. We notice very little difference in noise levels when operating, and time to retract and extend is comparable for like size slides. The only real difference we see is that the hydraulic slides require the key to be on to operate, and the electric do not.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
NC Hauler
Asheville NC
I've had both, never had problems with either electric or hydraulic.
Hydraulic is faster, I don't necessarily agree that hydraulic is smoother, quieter, or less troublesome. Guess it depends on what comes on the unit you get. Both work well, the newer electric ones are as smooth as the hydraulic and will last as long as the hydraulic. I know with the hydraulic slides I had, you needed to put the "stop's" in when slides were in to come them from coming out in case something happened to the hydraulics, but, some come with check valves, meaning, they don't need the stops, I've never owned an electric system that needed the stops. Both ststems, should something happen to them, would need to be opened and closed by hand, a real pain no matter what you own. Again, I don't believe your going to go wrong with whichever one you get.
edited 07/28/08 08:00pm by NC Hauler *
Jim & Kathy
07.5 Chevrolet K3500DRW/CC/LB/LMM/D/A LTZ, Prodigy,Reese 20K hitch.
06 HR Presidential Suite 37RLQ
06 Coachmen Clipper Classic 1270ST
99 Jayco Quest 10
07 Mitsubishi Outlander XLS 4X4
Boxers,Sheba,13..Buddy..1.5 yr.
USAF 71-75 Nam Vet
klassic
Smithville, Ontario Canada
If you go with hydraulic make sure you have slide selector valves. I've had to use my selector a few times now.
I've had both, hydraulic is much faster. I wish my landing gear wasn't electric.
klassic
2009 CC Silverback GII 34WBH
2009 F250 PSD Lariat Crew
Reese Signature Series 18K slider underbed rails
Line-X
Eclipse AVN 5435 DVD/NAV
