scottcougar
Saskatchewan
How hard do u make a sway bar? do u have to loosen it before every curve or corner? or just when backing into site?
Polishnurse
Schodack, NY
To be honest when I pulled a trailer, the sway control was also the weight distribution. The Car I was pulling it with would drop four inches if I took it off. So I always left it on till I was ready to drop the trailer where it was going to sit.
I know others on here with these moncho trucks don't have that concern. But the few turns you make with it engaged arn't that many. It is also designed to to take turns. But that was just me, and that was over fifteen years ago and don't think the engineering has change all that much. Bill
Terryallan
NC
The sway bar came adjusted from the factory. The adjustment is in the nut/bolt under the handel. The Handel is simply a on, off lever. Bottom it out, and make it level with the tongue.
No. you don't have to remove it to turn. You are supposed to loosten the handel some in the rain, and most directions say to remove it when backing.
Terry & Shay
Pioneer 23T6
04 F150, 5.4, Lariat SuperCab
Lazy Campers
NC
ispy
Alberta ,Canada
We just got a new sway bar and weight dist. setup for our new trailer and the dealer told us to tighten the sway bar until it was tight, don't overforce it. He told us never to back up with it on. So if yours is like ours, you turn it a few times until tight and thats it. Hope that helps.
2007 Suburban
2007 Jayco Jayfeather 30R
Family of 5 and 1 great mutt.
steelpony5555
Copperas Cove Texas
Tighten it down and then back it off a half a turn
05 Trail Bay 27DS
07 Tundra SR5 4.7
00 Harley Electra Glide (My Baby)
07 Civic for cheap gas
Margarita machine---nothing better then sittin in the shade on a hot day sippin a Margie!
The Black Pearl
Ottawa
What I was told is to use your two fingers closest to your thumb and tighten the bar down as much as you can with only your two fingers. Works for me....
2004 Trailblazer Extended
2005 22' Sunvalley Roadrunner 210BH
GVRW 4750 - Minus UVW 3360-Minus freshwater 266.56-Minus LP tanks 22.5-ccc 1,100.94
Prodigy Brake Controller
Eaz-Lift hitch
Distribution Bars rating 550lbs
Sway control
Top Pop Rails -3 bikes
Hornet28BHDS
Parker, PA
steelpony5555 wrote: Tighten it down and then back it off a half a turn
That's what I do! You don't need to take it off for turns, but you do need to take it off when backing up.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
Jim&Peg
Central Ohio
You tighten it all the way then back off to align the lever with the bar. If you feel you need more or less friction, the nut on the bottom is to be turned in 1/4 turn increments then tested. The only reason to take it off when backing is to prevent breaking it if you jackknife too far. I used one for years and never loosened it when backing, just was careful not to turn too sharply. The friction will have no affect on backing.
samsontdog
Sac. Ca summer, Yuma Az winter
I have been using the friction bar since they came out about 45 years ago. I tighten the bar down real snug even with the tongue. I have never removed for backing or turning or in the rain ! The only time I remove is when I set up in a site when I disconnect the TT. It has worked for me for thousands of miles and a lot of different TVs
samsontdog
scottcougar
Saskatchewan
so when u say tighten it up you mean the handle right? There is a nut/bolt on mine to but thats for more tension right? or increase in wear then i adjust that nut right? otherwise just use the handle?what comes adjusted from factory the handle or the nut part?
